Old 04-04-2018, 04:58   #1
RRI @ 9740 kHz
I don't know if this log has actually identified RRI on 9740 kHz or not. I received no FAC, but I thought the result was interesting anyway.
BTW, I've switched to an old 8GB Sandisk Cruzer USB device. We'll see if any improvement occurs over my other device. It shouldn't matter if the firmware is correct.
Old 09-04-2018, 19:16   #2
April 9th, 2018 partial log ... This time the signal was definitely there, but my GR-216 failed to detect and log those values. The MER (MSC) peaked at about 7 dB from the rear lobe of this RRI broadcast to India.
Old 15-05-2018, 04:46   #3
May 15th, 2018 partial log as the first 18 minutes were spent in vain trying to log with my GR-216. Signal levels were highest during the first 15 minutes and averaged SNRs ~ 10 dB with my GR-216. Until some of the bugs are fixed in my GR-216, I'm suspending logging with it. Don't get me wrong. I love the GR-216, but the logging bug is driving me nearly batty.
Here's nearly 45 minutes of the log from the reverse lobe of RRI's beam to SE Asia with my SDR-4+
Old 17-05-2018, 16:47   #4
May 16th, 2018 log ...
Codec: -
Frequency: +
Modulation: -
Old 19-05-2018, 04:51   #5
May 19th, 2018 partial log ...
Codec: -
Frequency: +
Modulation: -
Old 22-05-2018, 02:17   #6
May 21st, 2018 partial log ...
Codec: -
Frequency: +
Modulation: -
Old 22-05-2018, 13:18   #7
May 22nd, 2018 log ...
Codec: -
Frequency: +
Modulation: -
Old 24-05-2018, 00:23   #8
May 23rd, 2018 partial log ...
Codec: -
Frequency: +
Modulation: -
Old 24-05-2018, 21:18   #9
Lightning-Spangled Skies
May 24th, 2018 log ... stormy weather to say the least, but my SDR-4+ and magnetic loop handled it alright. I insist that my equipment work under such adverse conditions even if poorly. When emergencies arise, it's better to have equipment work somewhat than not at all.
Codec: -
Frequency: +
Modulation: -
Old 25-05-2018, 18:46   #10
May 25th, 2018 partial log ... I missed the first part due to a personal recommendation via e-mail for Ted Randall of WTWW to use DRM...
Codec: -
Frequency: +
Modulation: -
Old 27-05-2018, 20:26   #11
May 27th, 2018 partial log ... Due to technical problems, I split the broadcast in two parts. The signal was quite strong at times for reception off the reverse lobe.
Codec: -
Frequency: +
Modulation: -
Old 28-05-2018, 18:52   #12
May 28th, 2018 partial log ... I'm really beginning to wonder if this broadcast is being received from a rear lobe. Only listeners around India know for sure.
Codec: -
Frequency: +
Modulation: -
Old 29-05-2018, 20:31   #13
May 29th, 2018 log ...
Codec: -
Frequency: +
Modulation: -
Old 29-05-2018, 23:31   #14
Had a listen for this one yesterday here in New Zealand and found some good decoding at times.
Old 30-05-2018, 17:55   #15
May 30th, 2018 partial log ...
Modulation: -
Codec: -
Frequency: +
Chris, it's great to see some acceptable decoding from RRI's questionable configuration ... Excellent reception at a distance of 10,000 miles.
