Old 11-09-2018, 19:38   #1396
Sep 10th, 2018 partial log ...
Frequency: +
Modulation: +
Codec: -
Except for the codec and Mode C, VoN's configuration is one of the best on the shortwave bands. Quality of VoN's remote production could be improved though.
Old 14-09-2018, 09:24   #1397
AlexDRM
Hi Tom,
does Mode C 16-QAM provide a more robust signal than Mode B 16-QAM?
Alex
AlexDRM is offline   Reply With Quote
Old 14-09-2018, 14:36   #1398
Originally Posted by AlexDRM
Hi Tom,
Alex
Alex,
Theoretically, yes. Practically, no in my experience. Over the years, I've frequently witnessed wide variations between theory and practice. Even controlled experiments can NOT necessarily determine the overall experience of a human, in this case by a listener. I wish VoN would switch to Mode B while retaining 16 QAM modulation. Mode B works well for intercontinental digital broadcasts while allowing more capacity than Mode C.
Old 15-09-2018, 22:50   #1399
Sep 15th, 2018 log ...
Frequency: +
Modulation: +
Codec: -
Old 16-09-2018, 12:57   #1400
September 15th, 2018
Strong signal, until 19:30 UTC. MER MAX: 22 dB.
Video: https://youtu.be/Ew1OSi7COCg
Francisco Braccini
Cordial 73 from South of Brazil!
Old 21-10-2018, 18:03   #1401
Can someone explain why VoN CONSISTENTLY has problems staying on the air? I'm not necessarily referring to a consistent schedule, either. VoN seems to be off the air more than it is on the air. Naturally, it would be nice if VoN could fix their scheduling problems as well. I wonder if VoN is even broadcasting analog on shortwave currently. Even a revised digital schedule encompassing a couple days a week would be FAR preferable to the current situation, but the transmitter needs to be capable of doing so. I have a difficult time grasping this ongoing situation with VoN.
VoN, listeners require SOME sort of reliability from you. What ails VoN????
Old 12-02-2019, 17:32   #1402
VoN is back, I'm currently getting a fair signal from it on 15120 kHz, though the band is on its way down here now that it has gone dark.
Modified NRD-525G with
Radiokit DRM Decoder Board,
SDRplay RSP-1A, SDR Console v3
Lancashire, UK
53:39.18N 02:10.28W
IO83vp
https://www.ndblist.info
Old 15-02-2019, 15:57   #1403
Radioeng
Good signal at 16.55 UTC. SNR of 23dB. Perhaps on a new schedule?
Radioeng is offline   Reply With Quote
Old 15-02-2019, 18:26   #1404
1600 to 1800 UTC now I believe.
Lancashire, UK
53:39.18N 02:10.28W
IO83vp
Old 15-02-2019, 22:19   #1405
Left my receiver listening to 15120 kHz by itself overnight, and see some very faint traces of signal around 1600 UTC, so I'd go with an earlier transmission time too. Though there is a little spike around 2000 UTC too, but that may just be noise. Even at the best of times VoN has never been decodable here in NZ.
Old 17-02-2019, 15:16   #1406
Radioeng
Noted today in Arabic at 16.05-16.15, then in African language (Hausa?). Yesterday there was a transmission in an African language from 16.15 to 16.30 between two segments in English.
Old 18-02-2019, 15:18   #1407
AlexDRM
The African language is Yoruba.
Old 21-02-2019, 17:40   #1408
Frequency: +
Codec: -
Modulation:+
I'm pleased with VoN's new schedule. Except for the codec, VoN's configuration and time are far better than most digital broadcasters. Keep it on a regular schedule, VoN!
Old 22-02-2019, 18:16   #1409
I probably won't post the log since the signal is virtually non-existent, but I did notice a digital broadcast of at least 3 hours.
On VoN's historical unreliability, some of it is likely due to their location in the tropics which is detrimental to electrical equipment. Personally, if I were manager of this station at Abuja, the transmitters would be located below ground.
Old 23-02-2019, 16:05   #1410
Feb_23
A result for 128 mins. 83.87% CDA / 24.4dB max SNR. Weak signal + fading caused almost continuous dropouts. After ~16:09 the results turned much better.
