Old 04-02-2014, 07:56   #16
SW Speed: Average, SW Density: High
Environmental Noise: PC & M2 off ( 0 dB loss )
I won't rate this partial log.
Old 09-02-2014, 09:15   #17
SW Speed: Average, SW Density: Average
Environmental Conditions: PC on, M2 off ( 2 dB loss )
Decoded Audio: Fair
Even with power to my PC, the result was acceptable. I could have cut power to improve the result, but ...
Old 10-02-2014, 08:28   #18
SW Speed: High, SW Density: Average
Environmental Conditions: PC & M2 off ( 0 dB loss )
Decoded Audio: The sound of music ( perfection )
Old 15-02-2014, 23:25   #19
RNZI with splatter from DPRK on 11.680 MHz. Logged 13 minutes from 0744-0757 UTC. 81.45% CDA.
Old 21-02-2014, 00:15   #20
20th Feb
RNZI with very strong splatter from DPRK on 11.680 MHz. No log.
Old 24-02-2014, 11:24   #21
Decoded Audio: Fair
Old 25-02-2014, 10:48   #22
SW Speed: High, SW Density: High
Decoded Audio: Good
Old 26-02-2014, 08:13   #23
Decoded Audio: Excellent
Old 28-02-2014, 11:35   #24
Environmental conditions unknown as I wasn't planning on posting this log.
Old 28-02-2014, 11:36   #25
I won't rate this partial log, but the result would have been perfect if I had captured the whole log.
Old 01-03-2014, 08:17   #26
Decoded Audio: Unacceptable even though total decoding was ~ 88%. A MSC of 16 QAM would have helped here, too. As countless logs over the past decade have demonstrated at recommended power levels, a MSC of 16 QAM works reliably on shortwave whereas a MSC of 64 QAM does not.
Old 02-03-2014, 08:52   #27
RNZI logged 55 minutes from 0701-0757 UTC along with splatter from DPRK on 11.680 MHz. 17.61 dB max. SNR and 44.53% decoded audio.
Old 02-03-2014, 12:37   #28
Old 04-03-2014, 03:01   #29
Decoded Audio: sound of music ( perfection )
Old 04-03-2014, 08:20   #30
