Old 26-06-2018, 19:58   #226
Originally Posted by Digger
Like I said, I might be wrong. Would yo be able to produce the 12 kHz IF file? Many thanks.
PS: The IF file played OK with both the Gospell and the Avion receivers. 4/64 QAM, but I have no indication of the bitrate. Enclosed is a spectrum of the audio. It seems to stop around 10500 Hz. The music part in the middle of the file was overdriven and sounded poor. Otherwise the audio was very clear.
Terje,
If you have the time, please upload the decoded audio in a good compressed format, e.g. AAC+, so potential buyers can assess xHE-AAC's quality.
On second thought, I don't really have time currently to experiment with my LP DRM transmitter.
Old 26-06-2018, 19:58   #227
http://i63.tinypic.com/1e3s7d.jpg
I used my LP AM stereo transmitter with the channels swapped.
I never did hear any audio, but it isn't surprising given my GR-216's penchant for needing abnormally higher SNRs for decoding.
Old 12-07-2018, 16:41   #228
This afternoon I receive then name from Kuweit of 15110 Khz :
https://nsa39.casimages.com/img/2018...2632326539.jpg
Old 31-07-2018, 14:07   #229
July_31
Almost same QRM scenario as in my post #218 but worst. ~94% CDA / 32.3 max SNR.
Old 22-09-2018, 15:51   #230
September 22nd, 2018
No signal in South of Brazil. CNR & VoA AM signal only:
https://youtu.be/RXgyxQQLWz0
Francisco Braccini
Cordial 73 from South of Brazil!
Old 30-09-2018, 13:39   #231
Sept_30
I run this log after the CRI QRM stopped. Then appeared the QRM by VOA weaker than that of CRI, which affected a bit the decoding. 99.9% CDA / 30.5dB max SNR.
Old 22-10-2018, 14:10   #232
15110 kHz Radio Kuwait Reception near Atlanta, Georgia, USA
This morning's reception - 0.05% audio decoded, 13.47 dB max SNR.
Old 23-10-2018, 13:39   #233
This morning's reception - signal appeared (due to propagation) at about 11:38z and looks like an early transmission termination at 12:38z.
Old 24-10-2018, 15:09   #234
This morning's reception (last 1 hour and 51 minutes of transmission) - 19.04% audio decoded, 16.39 dB max SNR.
Old 25-10-2018, 13:35   #235
This morning's reception (last 2 hours of transmission) - 13.55% audio decoded, 16.44 dB max SNR.
Old 26-10-2018, 13:55   #236
This morning's reception (last 1 hour and 50 minutes of transmission) - 8.51% audio decoded, 16.17 dB max SNR.
Old 27-10-2018, 16:02   #237
This morning's reception (last 1 hour and 50 minutes of transmission) - 2.85% audio decoded, 14.72 dB max SNR.
Old 28-10-2018, 12:51   #238
This morning's reception (last 56 minutes of transmission) - 10.94% audio decoded, 14.94 dB max SNR.
Old 29-10-2018, 12:58   #239
This morning's reception (last 1 hour and 50 minutes of transmission) - 7.01% audio decoded, 15.20 dB max SNR.
Old 30-10-2018, 12:40   #240
This morning's reception (last 1 hour and 50 minutes of transmission) - 6.83% audio decoded, 15.21 dB max SNR.
