Old 01-04-2018, 09:19   #1
BBC Kranji (SNG) 15620 Khz.
I juste receive litel signal from BBC Singapoor of 15620 Khz, only receive screen picture no audio strong fading :
http://nsa39.casimages.com/img/2018/...1053476067.jpg
Old 02-04-2018, 10:03   #2
This morning signal DRM from BBC Singapoor of 15620 Khz was very poor strong fading :
http://nsa39.casimages.com/img/2018/...5346158887.jpg
Old 11-04-2018, 15:22   #3
Vary bad signal from BBC Singapor this morning of 15620 Khz QRN and fading, I have receive 5 secondly audio. I test with Sodira and Dream :
http://nsa39.casimages.com/img/2018/...1258280097.jpg
http://nsa39.casimages.com/img/2018/...1324939658.jpg
Old 12-04-2018, 19:30   #4
Apr 12th, 2018 log ... Although I never received any FAC, I believe the signal was present at nearly 15,000 * km from the transmitter and my indoor magnetic loop. Although I'd probably question the BBC's justification for switching to a lower frequency (probably solar minimum) the switch to 15 MHz was a good move regardless.
Frequency: +
*Codec: -
*Modulation: -
* Assumptions since I don't have the actual data from this broadcast including lobe of the beam.
Old 30-04-2018, 19:09   #5
I receive yesterday april 29.2018 BBC Kranji of 15620 Khz, very difficult reception signal is poor, no audio only screen :
https://nsa39.casimages.com/img/2018...5816791433.jpg
Old 29-05-2018, 23:42   #6
A couple of seconds of audio only from the Beeb on 15620 kHz here in New Zealand yesterday.
Old 14-06-2018, 02:52   #7
15620 kHz on13th June 2018
BBC from Kranji. Some faint traces of signal around 0845 UTC, "English" and ID seen in DReaM, but not enough to get the Label.
Old 14-07-2018, 12:24   #8
This morning I have signal at 8H08 UTC from BBCWS Kranji of 15620 Khz signal was SNR 5 to 16,4 db, many audio cut from fading, SNR 5 to 16,4 db.
Best signal was aroun 8H15 UTC to 8H26 signal was poor SNR 7 db and 8H49 UTC signal was vey poor no decodable :
https://nsa39.casimages.com/img/2018...2134247624.jpg
Old 13-08-2018, 16:01   #9
This morning I receive BBC WS of 15620 Khz poor signal SNR : 6 to 9,6 db no audio only screen, in FM mode, no possible in AM or SSB !!!!! :
https://nsa39.casimages.com/img/2018...4929749806.jpg
Old 15-09-2018, 05:52   #10
14th Sep 2018
BBC WorldService via Babcock in Kranji logged for 49 minutes from 0809-0858 UTC. Traces of signal, "English" and ID in DReaM, and enough to get the Label. Max.11,17 dB SNR but 0,0% decoded audio.
Old 27-09-2018, 18:32   #11
I receive BBCWS of 15620 Khz only short audio :
https://nsa39.casimages.com/img/2018...4629153277.jpg
Old 01-12-2018, 08:03   #12
BBC World Service Dec 1st
I keep forgetting to check this transmission. It appears I should check more often! 98% audio decoding of 15620 kHz here in NZ tonight, good sounding audio and Journaline service.
Old 04-12-2018, 08:02   #13
Only 38% decoded in NZ on December 4th.
Old 05-12-2018, 08:03   #14
15620 kHz, 0800-0900 UTC December 5th
58% decoded in NZ on December 5th on 15620 kHz, 0800-0900 UTC. Audio sounds good when it does decode.
Old 06-12-2018, 08:06   #15
December 6th log of 15620 kHz in NZ. Only decodeable for the last 10 minutes of the broadcast.
