Old 17-04-2018, 01:50   #46
RRI, 11650 kHz, Reception near Atlanta, Georgia, USA
Signal was there but very poor reception.
34°02' N, 84°24' W
Old 18-04-2018, 00:33   #47
Signal was there this evening, but poor.
34°02' N, 84°24' W
Old 18-04-2018, 09:03   #48
RRI 11650 khz 17 Apr Reception Naples Florida
85% copy when I checked at 2120-2135.
Gospell GR-216 and Wellbrook ALA-1530.
Old 19-04-2018, 00:11   #49
This evening's report - 0.41% audio decoded, 11.16 dB max SNR.
34°02' N, 84°24' W
Old 19-04-2018, 22:56   #50
RRI 11650 kHz DRM in South Brazil 19 APR 18
Strong signal in Brazil. I'm traveling bus and could decode any frames with Avion + Actives antennas Degen and Sony together kkk
Old 20-04-2018, 00:43   #51
Cool, it's the way life SHOULD be with digital shortwave.
Old 20-04-2018, 01:15   #52
Solar explosion yesterday http://www.solarham.net
Old 20-04-2018, 04:25   #53
This evening's report - 11.48% audio decoded, 15.08 dB max SNR.
34°02' N, 84°24' W
Old 21-04-2018, 00:44   #54
Absolutely no signal received this evening.
34°02' N, 84°24' W
Old 21-04-2018, 14:48   #55
RRI 11650 kHz DRM in South Brazil 20 APR 18
Bad signal. MER MAX: 4dB.
The propagation fell in the band of 25m, when the RRI 11850 kHz AM in English, weakened, at 20:40 UTC. At 21h UTC, there were no more conditions for the 11650 DRM in Spanish.
Old 22-04-2018, 00:44   #56
Just a trace of signal this evening.
34°02' N, 84°24' W
Old 22-04-2018, 23:22   #57
This evening's report - the signal improved towards the end - 1.15% audio decoded, 11.57 dB max SNR.
34°02' N, 84°24' W
Old 22-04-2018, 23:30   #58
RRI 11650 kHz DRM in South Brazil 21 APR 18
Strong signal, until 21:40 UTC. Vídeo: https://youtu.be/F3oerZvih_Y
Old 23-04-2018, 00:36   #59
RRI 11650 kHz DRM in South Brazil 22 APR 18
Good signal, since 21:15 UTC: https://youtu.be/RfYENVST2rg
Old 23-04-2018, 00:49   #60
I listened to about 10 minutes and the result was very good with few periods of silence at 16 QAM. In comparison to the BBC's recent broadcast to the DRM's GA which barely could be received at 50% in parts of Spain near the center of the beam and from a relatively short distance, this broadcast from RRI was received fairly consistently at a relatively long distance. Consistency in decoding should be the primary goal of every digital SW broadcaster. At times, I think some DRM SW broadcasters are really narrowcasters. Maybe, those DRM SW narrowcasters in love with 64 QAM modulation should modulate a high-powered laser beam instead.
Also important, your receiver is much more typical of the average listener than the more expensive and elaborate setups of some members on the DRMRX forums, including myself.
