Old 15-06-2018, 12:21   #61
Friday morning, 15/6/18, in downtown St. John's, Newfoundland. I finally heard some audio from WINB DRM! I had turned on both my MorphyRichards 27024 (with an 8m wire outside) and my Avion DR1401 (with a Sony AN-LP1 loop antenna inside the house, pointing SW). I was looking at the two radios' responses to the WINB signal. On the MR it varied between 0 dB MER and 16 dB. On the Avion it was from zero to 12 dB.
Suddenly a burst of audio came out of one of them. It only lasted about a half-second, long enough to recognise a child's or a woman's voice in what sounded like acted anguish. Then it was gone.
I had the two radios stacked at that point and, to be honest, I don't know which one produced the audio!
But I do know that one of them *can* decode whatever WINB is producing, at least sometimes.
A day or two ago, I had noticed that the AM-decoded audio on 15670 is a complex tone rather than the usual audio whoosh of DRM. Right now, at 1155 UTC, I hear the tone-audio (on my Satellit 750), while seeing low MER rates and the WINB label on the two DRM sets.
EDIT, five minutes later.
At 1202, the Avion leapt into audio action and produced about twenty seconds of audio from the WINB DRM signal. It does work. . .
Old 15-06-2018, 12:35   #62
By the way, *very* momentarily, a few minutes after that audio spurt, the Avion showed a number 2 in its programme indicator, suggesting it was picking up a second programme, at least for a moment (well under a second). I wonder if this was simply a glitch in the Avion, or an indication of a data stream.
Old 15-06-2018, 14:00   #63
Hi Philip,
It was probably a momentary glitch, because the data signal that WINB is simulcasting is not part of the actual DRM encoding.
As mentioned before the technical specifications of DRM do not recommend simulcast with DRM on HF.
So far, judging from all reports, the WINB DRM reception is marginal at best.
Old 15-06-2018, 14:52   #64
It is just coming up to 1430 Friday (15/6/18) now and I've been able to sit by the radio most of the past three hours, catching little snippets of speech from the WINB DRM on 15670 kHz. None of the snippets lasted more than twenty seconds and they are separated by ten and fifteen-minute segments of DRM silence, so it's not exactly a great listening experience. . . .
I am struck, once again, by how poor this DRM audio is. It does not have to be so, because I do hear good sound from, say, RRI. But it often seems highly compressed, making it difficult to pick out the speech when someone's accent is different from my own. It sometimes seems slewed towards bass frequencies (like V Nigeria) but here, with WINB, it seems EQ'd towards a tinny, higher-frequency sound.
I'd like to be able to analyse that audio to figure out what they are doing. I have an old but well-functioning copy of Sony Sound Forge. It can do some spectrographic analysis, but not precisely what I would like. Does anyone have anything to suggest for analysis of broadcast sound to be able to make clear comment on the EQ?
Old 15-06-2018, 16:41   #65
Originally Posted by MARCEL
Bonjour tpreitzel,
Sorry, but the problem it is my English which is very bad, I do as I can, thus the I use a translator.
I decoded WINB from 11:42 am UTC approximately 10 at 13 minutes, with more or less long cuts of in the important fading, from 12:20 am the signal begins to fall and at 12:21 am more by audio,
At 12:12 am the emission was in Spanish language,
Marcel,
I know that English can be difficult so I thank you for your explanation. Your English is far, FAR better than my French.
Merci
Old 15-06-2018, 16:44   #66
Jun 15th, 2018 partial log ...
Codec: -
Modulation: -
Frequency: +
Old 15-06-2018, 16:46   #67
I checked the audio bandwidth the other day and it was only 3 kHz.
WINB is running their Simulcast DRM service in half the normal bandwidth at 5kHz using 64-QAM in the most robust mode..
This only allows 8.28 kbps of DRM data. Even if they switched to 16-QAM with the same robust signal coding then the available DRM data would only be 5.5 kbps and the resulting audio would be far more limited. (Reference: EBU Tech 3330 page 15).
However, as the main aim of WINB is data transmission and not the DRM broadcast, we should not be surprised!
Old 15-06-2018, 16:53   #68
Although quite complex, you might try Sonic Visualiser or Audacity for Linux. Hopefully, other members can recommend something similar for Windows.
Yeah, the quality of audio is poor due to the poor choice of 64 QAM modulation at a low bit-rate. The use of higher bit-rates for HE-AAC+ like RRI renders decoding unreliable. The HE-AAC+ codec is really only viable on the MW band, but can be used on SW reliably with 16 QAM modulation. The muffled audio is probably due to the lack of SBR, but can be due to poor production, e.g. poor quality of the remotes in VoN's broadcast. The use of 16 QAM modulation would lower the threshold for decoding while still allowing sufficient robustness and quality, but this fact has been known for more than a decade.
I'll forgo any opinion at the moment on WINB's potential application for this broadcast, but 64 QAM modulation is certainly NOT the right choice for reliable decoding of audio in ANY configuration on shortwave bands.
To achieve a good balance between quality and reliability on the SW bands, digital broadcasters in 2018 should certainly be using 16 QAM modulation WITH the xHE-AAC codec. I should add that even with the latter combination, a broadcaster can even screw-up that excellent combination with poor production.
Old 16-06-2018, 01:18   #69
TP, thanks for those suggestions. Forty-odd years ago, I used to use a (then-old!) Kay Spectrograph for analysing short speech segments. It was very limited but very elegant in its output, on little sheets of coated and point-burnt paper. I have never seen software quite as simple and useful. But Sonic Visualiser may be exactly the thing I was looking for.
Old 17-06-2018, 19:52   #70
Audio extract from WINB June 14.18 :
Voir le Fichier : DRM_WINB_14618_15670_11H42.mp3
Old 18-06-2018, 06:45   #71
Thanks for the WINB 8,28 kbps DRM sound sample, Marcel. It does not sound *so* terrible after all. I recorded the audio with Audacity.
And thanks for the TDA 891 kHz 12 kHz IF file from April last year. I played it on one PC and modulated a signal generator set to f kHz, fed the RF to the GR-216 which was tuned to f+12 kHz. I recorded the xHE-AAC audio (JIL FM, Ch.2 with 6.94 kbps, sample rate 32 kHz, No SBR) on a notebook with Audacity installed.
Enclosed are two screenshots from Audacity, one of WINB and the other from TDA with xHE-AAC. There is a significant increase in audio band width with the xHE-AAC signal.
Old 18-06-2018, 15:25   #72
Attached is the Dream audio spectrum display received via the KiwiSDR receiver in Weiser, Idaho, USA just minutes ago.
The audio does not remain for more than a couple of seconds or so and then disappears.
The audio quality, when its there (as I had mentioned before) is "quite good".
Old 18-06-2018, 15:52   #73
WINB with FLdigi
Quite easy to look at the WINB datacasting portion of the signal with FLdigi (see Attachment - small size because of Forum's file size restriction).
The data signal is there even when the DRM is not.
You cannot, of course, know what type of data signal is being used.
Old 21-06-2018, 19:17   #74
Jun 21st, 2018 partial log ...
Frequency: +
Codec: -
Modulation: -
Old 22-06-2018, 20:11   #75
Jun 22nd, 2018 partial log ... a bit longer than usual.
Frequency: +
Codec: -
Modulation: -
