Old 08-08-2018, 13:37   #46
I'm still struggling with this broadcast. Tonight I used my FRG-7700 for 139 minutes and got only 4,29% decoded audio. DReaM spurts audio when the SNR >14 dB. But the SNR average is below that most of the time. At least here.
Old 08-08-2018, 22:52   #47
August 8 overnight log from New Zealand.
73 Chris
Old 09-08-2018, 22:42   #48
August 9 overnight log from New Zealand.
73 Chris
Old 12-08-2018, 00:35   #49
11th Aug.
Voice Of China with a regular test broadcast aimed for China logged for 167 minutes from 1059-1357 UTC. Max.15,00 dB SNR and 0,28% decoded audio.
Old 13-08-2018, 05:44   #50
Voice Of China with a regular test broadcast aimed for China logged for 129 minutes from 1037-1246 UTC. Max.14,00 dB SNR and 0,23% decoded audio.
Old 13-08-2018, 13:51   #51
Tomorrow I'll try this active ferrite antenna tuned to 6,03 MHz outside instead of lying on a table inside.
Old 16-08-2018, 03:28   #52
14th Aug.
Hm, needs more testing.
Old 16-08-2018, 03:31   #53
15th Aug.
Were they off the air or was it my fault? No signal received at all here.
Old 17-08-2018, 03:14   #54
16th Aug.
Voice Of China with a regular test broadcast aimed for China logged for 186 minutes from 1100-1406 UTC. Max.16,00 dB SNR and 1,36% decoded audio.
Old 17-08-2018, 15:08   #55
China 6030 kHz KiwiSDR reception Yokohama, Japan
Today's reception via the KiwiSDR web receiver in Yokohama, Japan. Audio decoding was 83.12% for the hour and then the auto time-out switched off the internet feed.
The transmitting antenna, according to HFCC, is a single element dipole quadrant antenna at 0.3 wavelengths high. This is essentially a "short" range NVIS antenna with a mostly high angle lobe. This means that at a distance the signal has to go through a myriad of constantly changing paths that cause destructive multi-path fading at the receiver. Although the signal maybe strong the decoding is difficult.
It appears that the receive antenna at this location favors a lower angle signal thereby reducing the multi-path effect.
Old 18-08-2018, 01:16   #56
Voice Of China with a regular test broadcast aimed for China logged for 641 minutes from 1123-2204 UTC. Max.16,22 dB SNR and 0,06% decoded audio.
A rather embarrassing result compared to the log from Yokohama. The antenna used was an active ferrite antenna tuned to 6.03 MHz. This antenna produced a slightly higher SNR than the modified PA0RDT active antenna I usually use.
Old 19-08-2018, 22:49   #57
Log from New Zealand from August 19th.
Old 21-08-2018, 17:21   #58
Aug_21
Weak signal, co-channel QRM, I got the label though.
Old 24-08-2018, 02:56   #59
23rd Aug.
Another attempt to catch Voice Of China on 6030 kHz: This time I used an old EH Antenna for 6 (and 7) MHz which I had used in Switzerland a long time ago when Radio Sweden was testing DRM. Max SNR was 17,63 dB and 2,7% decoded audio. Because of the typhoon T20 I had to place the antenna inside. Very clear and good audio when there was some. Thumbs up for the Chinese engineers.
Old 27-08-2018, 03:59   #60
Yesterday (26th) evening in Japan around 10 UTC I listened to the VOC broadcast, and there was definitely something wrong with the audio. The DR-111 and DReaM with the FRG-7700 sounded the same, like a CD that sort of played out of sync. I'll check again tonight.
