Old 08-12-2018, 20:58   #106
6 hour overnight log from New Zealand on December 8th.
Old 11-12-2018, 22:59   #107
Overnight log from Dec 11th
Old 06-02-2019, 20:59   #108
Feb 6th log
6.5 hour log of 6030 kHz in NZ from Feb 6th.
Old 20-03-2019, 17:51   #109
Weak signal with interference.
Had to reduce the bandwidth and switch on a notch.
Have to update my DRMTX file, distance is wrong.
Very robust 4-QUAM for the SDC makes identification possible.
Old 21-03-2019, 00:02   #110
The DRM Plotter has (almost) all the TX sites "on board"! (Nicht bse gemeint ;-) )
Old 21-03-2019, 12:18   #111
Are the TX Sites still actually updated in DRM Plotter?
In my old DRMcalc drmtx.txt from 2013 Romania is still on this frequency.
Old 22-03-2019, 00:44   #112
I'm trying my best...
https://hobbyradio.se/drmshow/drmtransmittersites.txt
Old 22-03-2019, 07:33   #113
Thumbs up
I see, very good, much work!
Unfortunately different format incompatible with DRMcalc.
Old 22-03-2019, 08:31   #114
Then use the DRM-Plotter or:
- Open the file in Notepad
- Press Ctrl+H
- Replace "
- With (nothing)
- Replace all
- Press Ctrl+S
Voila!
Old 22-03-2019, 09:11   #115
WOW! You're da man! Thank you!
Hope you don't mind if I stick with DRMcalc.
Old 23-03-2019, 01:06   #116
China National Radio logged for 79 minutes from 1138-1258 UTC. Max. 10,41 dB SNR and 0,00% decoded audio.
Old 23-03-2019, 15:13   #117
Had to reduce the bandwidth to 9.5 kHz against AM carriers on +/- 5 kHz.
At 15:00 UTC CRI started in AM on 6025 kHz eliminating CNR's DRM signal.
