Old 03-01-2018, 21:04   #1321
Jan 3rd, 2018 log ...
Old 04-01-2018, 19:58   #1322
Jan 4th, 2018 log ...
Old 06-01-2018, 22:13   #1323
Jan 6th, 2018 partial log ... now back on former RG-6 cable as I've replaced my ATSC cable with newer RG-6 as well.
Old 08-01-2018, 19:47   #1324
Voice of Nigeria 15120 kHz reception near Atlanta, Georgia, USA
This afternoon's reception using the loaner Gospell GR-216 DRM receiver.
I don't know why the log shows a period of 1500 Frame decoding when it should all be 750 at VoN's bit rate.
Old 08-01-2018, 20:23   #1325
Jan 8th, 2017 log ...
Old 09-01-2018, 19:47   #1326
Reception worse than yesterday.
Old 09-01-2018, 21:35   #1327
Jan 9th, 2018 partial log ... due to other higher priority business...
Old 10-01-2018, 19:52   #1328
This afternoon's reception. The 2nd half of the transmission signal level very low.
Old 10-01-2018, 22:21   #1329
Jan 10th, 2018 log ... back to the business of digital shortwave radio which was marginally interrupted by a solar flare over the path of nearly 7000 MILES.
Old 11-01-2018, 21:36   #1330
Jan 11th, 2018 log ...
Last (weakest) part of path is ~ 1500 continental miles, i.e. no major sources of water. Distance is ~ 6915 miles or more than 11,000 km.
Old 13-01-2018, 20:57   #1331
Jan 13th, 2018 partial log ...
Last (weakest) part of path is ~ 1500 continental miles, i.e. no major sources of water. Distance is ~ 6915 miles or more than 11,000 km. Learn to observe the environment around you instead of relying so much on prevailing theories and simulators. You'll sleep better. You'll likely be as accurate as the "professional" forecasters in the process. You'll enjoy life better. Solar instability in progress ...
Old 14-01-2018, 19:57   #1332
Old 14-01-2018, 20:19   #1333
Jan 14th, 2018 log ...
Old 15-01-2018, 22:21   #1334
This afternoon's reception - logging started later than normal.
Old 15-01-2018, 22:27   #1335
Jan 15th, 2018 log ... very unstable atmospheric conditions regionally.
