Old 31-08-2017, 15:43   #1
Braccini
Voice of Korea (DPKR) - North Korea 3560 kHz from Kujang
New test broadcasting from North Korea!
Video: https://youtu.be/2ULr1yHv3rs
Braccini is online now   Reply With Quote
Old 01-09-2017, 15:30   #2
fibber
fibber's Avatar
DPRK on DRM
Why do you think it is Kujang? This broadcast seems to mirror (frequency and bitrate) of their 2012 experiments that originated from Qingdao, Shandong, China. Here is my original post: http://drmnainfo.blogspot.com/2012/0...community.html
Elad FDM-S1, HCJB Pappradio, Newstar DR111.
DReaM, DRM Software Radio.
JTV680 Vertical, 80M 1/2 Wave Dipole.
Christopher - "Fibber" - K6FIB
Salem, Oregon, USA
44.901951 -123.048109
CN84lv
DRM in North America? Join DRMNA!
http://groups.yahoo.com/group/drmna
or read the blog http://www.drmna.info
fibber is offline   Reply With Quote
Old 01-09-2017, 16:46   #3
fibber
fibber's Avatar
DPRK on DRM
The more I am researching this, you might be right. It was a partnership and initial broadcast for "Communication University of China Radio and Television Digital Education Ministry Engineering Research Center - CUC-ECDAV." So maybe the Chinese helped them install DRM equipment at Kujang? I'm inquiring if HFCC knows anymore about this one. I should know more next week.
Salem, Oregon, USA
CN84lv
Old 03-09-2017, 13:11   #4
Cumbredx
3560 Background Info
Hi All - I have listed links below, but 3560 kHz is an old and well-documented frequency of North Korea. It has been described as a feeder frequency (used to get programs to the transmitter site.)
3560 kHz was also a frequency used by the North Korea based clandestine station, Voice of National Salvation.
The next time a DXer catches one of these transmissions, it would be interesting to see if the transmission is running // to other Voice of Korea frequencies and measure the delay between the two. That might give some clues as to the transmitter location.
There have also been complaints issued by amateurs about the use of this frequency.
So while one can not rule China out, it might just be that North Korea is using this frequency to test DRM with a transmitter and/or equipment provided by China.
73s,
Hans Johnson
Current schedule for Voice of Korea - http://www.shortwaveschedule.com/index.php?station=58
Description of 3560 kHz as a VoK feeder http://www.w4uvh.net/dxld9062.txt
3560 kHz - Voice of Korea, the foreign service of North Korea, was heard here in DRM broadcasting in English in 2012. https://www.youtube.com/watch?v=kpNQ...ature=youtu.be
3560 kHz is listed as a 15 kW transmitter located in Kujang according to a Wikipedia entry at
https://en.wikipedia.org/wiki/List_o...in_North_Korea
Here is a link to some older google earth images of the site. http://www.northkoreatech.org/2011/0...nsmitter-site/
An older schedule for the use of 3560 kHz can be found at: http://www.northkoreatech.org/2010/1...sting-station/
VoK verified with a QSL reception of 3560 in 2008. http://www.schoechi.de/az-kre.html
Voice of National Salvation http://www.radiodx.com/introduction-...io-wars-1980s/
Amateur complaints http://www.w4uvh.net/dxldtd3i.html
Cumbredx is offline   Reply With Quote
Old 03-09-2017, 18:11   #5
Braccini
Thank you for comments Fibber. Clint 73!
Old 03-09-2017, 23:25   #6
It's probably a test transmission from North Korea, but it likely won't be for long, unfortunately. Kim, it's too late to turn back now.
Old 07-09-2017, 07:47   #7
We had a thread going about this back in 2012. One of my contributions can be found here:
http://www.drmrx.org/forum/showpost....0&postcount=51
http://www.hobbyradio.se/en/drm/webp....index_en.html
Old 11-09-2017, 14:36   #8
Braccini
10_SEP listening in Japan
Video by 2010DFS: https://youtu.be/TQVhaDBBK4Q
Old 25-09-2017, 08:50   #9
Cumbredx
3560 Back On?
Hi All - In checking an SDR in Japan at 0845, I can see the 10 kHz wide waterfall on 3560 kHz. I saw the same waterfall pattern in checking BBC in DRM on 17790 which is on this time.
73s,
Hans
Old 25-09-2017, 09:06   #10
It's a pity that I had to cancel my Japan trip in September. The reception was quite good in Shizuoka a few years back.
Old 25-09-2017, 10:18   #11
Cumbredx
3560 still on at 1014
still going at 1014.
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
