Old 11-04-2015, 18:48   #31
April_11
Good results only the about the last 10 mins although the signal was >65dBuV.
Old 27-04-2015, 18:38   #32
April_27
The meter points to ~70dBuV, strong signal, but the result is disappointing.
Old 12-06-2015, 18:47   #33
June_12
The signal is strong > 65dBuV but the results are disappointing. Tonight at the beginning seemed promising but in vain!
Old 27-06-2016, 18:45   #34
June_27
Strong signal. Erratic decoding ~1 min after the start up of the log. The rest result was almost perfect. After ~18:17 co-channel QRM affected the SNR.
Old 08-07-2016, 18:31   #35
July_08
A perfect result for 28 mins.
Old 05-09-2016, 18:36   #36
Sept_05
Although the signal was 60-70dBuV only ~93.8% CDA / 22.5dB max SNR.
Old 02-10-2016, 18:37   #37
Oct_02
Although the signal was about 65dBuV only 94.6% CDA / 24.7dB max SNR.
Old 11-10-2016, 18:36   #38
Oct_11
Srtong and stable signal but low SNR, perfect results.
Old 18-10-2016, 18:33   #39
Oct_18
A ~60dBuV stable signal gave a 100% CDA result.
Old 19-10-2016, 18:33   #40
Oct_19
When the path opened, the signal soon reached at an almost stable value of ~60dBuV, 100% CDA.
Old 20-10-2016, 18:32   #41
Oct_20
A bit unstable signal tonight, as a result some errors affected the decoding, ~99.4% CDA.
Old 25-10-2016, 18:30   #42
Oct_25
A ~60dBuV signal gave a 99.6% CDA result.
Old 26-03-2017, 18:30   #43
Mar_26
A 28 mins log. After 18:15 the signal dropped by ~30dB, no more decoding.
Old 27-03-2017, 18:25   #44
Mar_27
99.99% CDA tonight.
Old 28-03-2017, 18:28   #45
Mar_28
Only 82% CDA.
