Old 29-03-2017, 18:27   #46
Mar_29
~98.7% CDA tonight.
Old 02-04-2017, 18:39   #47
April_02
Although the RF signal was ≥ 60dBuV the SNR was low and the decoding erratic. ~83% CDA.
Old 04-04-2017, 18:36   #48
April_04
A better result tonight, ~96% CDA.
Old 06-04-2017, 18:25   #49
April_06
The RF signal was stable 60-70dBuV but with low SNR and erratic decoding, two TX breakdowns noticed, ~46% CDA.
Old 07-04-2017, 18:23   #50
April_07
Better results tonight, ~90% CDA.
Old 09-04-2017, 18:32   #51
April_09
Strong and stable signal tonight, 100% CDA.
Old 11-04-2017, 18:22   #52
April_11
99.58% CDA tonight.
Old 14-04-2017, 18:33   #53
April_14
A result at ~93% CDA.
Old 18-04-2017, 19:02   #54
April_18
A result at ~96.8% CDA.
Old 20-04-2017, 19:11   #55
April_20
A result @ ~99.8% CDA / 23dB max SNR.
Old 22-04-2017, 08:24   #56
21st April
RRI, SNR Saftica logged for 18 minutes from 1811 UTC. Max. 19.58 dB SNR and 69.18% decoded audio. Unstable decoding.
Old 05-05-2017, 06:51   #57
RRI, SNR Saftica logged for 25 minutes from 1802 UTC. Max. 21.48 dB SNR and 88.03% decoded audio.
Old 24-06-2017, 19:06   #58
June_24
Although the signal is around 70dBuV the decoding was very bad. I stopped of logging.
Old 25-06-2017, 04:04   #59
Why did the number of successfully decoded frame vary in zigzag like fashion? Local interference?
Old 25-06-2017, 15:47   #60
-1. No local QRM.
-2. About 10 dB fading. When the RF signal drops down to ~60dBuV decoding stops.
-3. Very low SNR, usual for this TX.
-4. My area inside side lobes.
-5. Bad IR.
-6. Of course, the high BR...
