Old 21-07-2017, 06:47   #1
Radio Kuwait - from the Archives
Hi All
With Radio Kuwait using DRM recently I went back through my DRM archives and found this recording of Radio Kuwait using DRM back in 2003 :-)
It was all very new stuff back then, and people didn't know how to set levels properly.
https://www.dropbox.com/s/ch8cff013b...0600.flac?dl=0
This was on 15110 kHz, recorded here in New Zealand. My notes say:
"Super Station FM 99.7 Radio Kuwait" peaking nicely for 15 minutes or so for the English news and weather at 0600 UTC, before disappearing into the murk. 14.3 kbps stream.
Old 01-11-2017, 10:48   #2
Hi Chris and all,
They're back on 15110 kHz in the B17 schedule and I'm logging it with the Gospell GR-216. I hope the newest software logs the Doppler and delay - will post later.
Old 01-11-2017, 14:22   #3
More than 99% decoded audio before I had to stop the log.
By the way, I forgot to say that the newest s/w for the GR-216 now supports Doppler and delay as well in the DRM logs. Thank you H.C.!
Old 01-11-2017, 14:35   #4
Hi Terje, do you know the time schedule?
Old 01-11-2017, 16:08   #5
Radio Kuwait on 15110 kHz from Al Kabd
According to the B17 data, the transmission is from 0945 to 1325 UTC.
Old 01-11-2017, 16:30   #6
John, I got it from Neil.
http://www.drmrx.org/forum/attachmen...9&d=1508429430
(I hope I got it right).
Old 01-11-2017, 16:52   #7
Thanks Terje!
Old 01-11-2017, 18:14   #8
Originally Posted by Owdjim
Hi All
Hi friend! It was in 2003 on DRM? 🤔🤔🤔
Old 02-11-2017, 06:15   #9
Received on Nov 1st in Naples, FL, USA for a few minutes around 1230. Nice P-stereo in the headphones. I lost the signal and it did not come back. Logged with Gospell GR-216 and Wellbrook antenna.
Old 02-11-2017, 13:25   #10
Nov_02
A partially unattended log in Arabic for 219 mins. 94.7% CDA / 34dB max SNR.
Old 02-11-2017, 16:50   #11
2 Nov 2017 : Radio Kuwait on 15110 kHz from Al Kabd
There was 99+% decoded audio during the transmission.
06:00-09:00 UTC Planetary K-index 1-. Local K-index 0.
09:00-12:00 UTC Planetary K-index 1. Local K-index 1.
12:00-15:00 UTC Planetary K-index 2-. Local K-index 2
Planetary A-index: 4. Solar flux: 73. EISN Sunspot number: 0.
Sunrise 06:58 UTC.
Old 02-11-2017, 18:49   #12
Perfect reception in this mostly unattended log.
Old 03-11-2017, 12:37   #13
Nov_03
Very good propagation conditions. A mostly unattended log for 3 H 40 mins. 99.99% CDA / 34.6dB max SNR.
Old 03-11-2017, 15:45   #14
3 Nov 2017 : Radio Kuwait on 15110 kHz from Al Kabd
06:00-09:00 UTC Planetary K-index 2-. Local K-index 1.
09:00-12:00 UTC Planetary K-index 2+. Local K-index 2.
12:00-15:00 UTC Planetary K-index 2+. Local K-index 2
Planetary A-index: 8. Solar flux: 73. EISN Sunspot number: 0.
Sunrise 07:00 UTC.
Old 03-11-2017, 18:17   #15
Naples Reception
some audio for several minutes at around local sunrise, 1145 UTC.
