Old 04-11-2017, 12:59   #16
Nov 4 Reception in Naples Florida
Same like yesterday, audio around local sunrise and then just down to the label after that.
Old 05-11-2017, 06:59   #17
4 Nov 2017 : Radio Kuwait on 15110 kHz from Al Kabd
There was 99+% decoded audio during the transmission.
06:00-09:00 UTC Planetary K-index 0+. Local K-index 0.
09:00-12:00 UTC Planetary K-index 0+. Local K-index 1.
12:00-15:00 UTC Planetary K-index 1-. Local K-index 1
Planetary A-index: 9. Solar flux: 73. EISN Sunspot number: 0.
Sunrise 07:02 UTC.
Old 05-11-2017, 08:01   #18
224 minutes of almost perfect decoding. Max. 31 dB SNR with the GR-216.
Old 05-11-2017, 09:57   #19
receive from kiwiSDR through the web
Just in case anyone want to receive DRM broadcast via the web, I just manage to record this screen shot from kiwiSDR, reception location Greece.
Nice feature from SDR and very good reception quality indeed.
Regards
Old 05-11-2017, 11:20   #20
Originally Posted by zfyoung
Nice feature from SDR ... zfyoung
I wonder if Chris (owdjim) plugged this feature?
Old 05-11-2017, 11:45   #21
I don't think this "kiwiSDR" has any relationship to the forum member
Code:
Chris (owdjim)
as you suggested, even though they both are probably from New Zealand.
Anyway, I provide the link to kiwiSDR web page for anyone interested in their web-enabled SDR.
http://www.kiwisdr.com/
Old 07-11-2017, 13:24   #22
Nov_07
A mostly unattended log for 3 H 50 mins. 98.91% CDA / 34.2dB max SNR.
Old 07-11-2017, 19:58   #23
7 Nov 2017 : Radio Kuwait on 15110 kHz from Al Kabd
06:00-09:00 UTC Planetary K-index 3+. Local K-index 2.
09:00-12:00 UTC Planetary K-index 5-. Local K-index 4.
12:00-15:00 UTC Planetary K-index 3. Local K-index 2
Planetary A-index: 2. Solar flux: 70. EISN Sunspot number: 0.
Sunrise 07:07 UTC.
Old 09-11-2017, 10:13   #24
Which SDR has DRM?
Regards
Which SDR in Greece has DRM? There are a number of receivers there. URL for this receiver?
Old 09-11-2017, 10:57   #25
All Kiwi SDRs Ver. 1.4.1 have IQ output.
Here is a log with the Kiwi SDR in Hamburg (DN5HAT). The interruptions in the audio seem to be receiver related. Sometimes an error msg "audio underrun" pops up. If that had not been the case the decoded audio would have been much better.
Old 09-11-2017, 11:59   #26
Just select ANY SDR that is vacant (kiwiSDR has a limit on number of simultaneous loggers for each device). In my case, I just select it randomly (and it happens to be in Greece). I think any receiver in western Europe has good chance of decoding.
Old 10-11-2017, 08:48   #27
DRM via SDR
OK, let me see if I have this right. You are using the SDR audio as your input and then
running it in dream to decode it and the plotter to display it, correct?
Old 10-11-2017, 09:41   #28
running it in dream
Yes, you are almost there. Simply put it: remote receiver, local decoder.
As Digger said, you need good network connection between remote server and your local PC. If there is any IQ data dropped out in real time, you can easily spot out a black "gap" in Dream waterfall graph.
Old 10-11-2017, 09:47   #29
Thanks
Thanks to you both, I didn't realize that could be done.
Old 10-11-2017, 13:13   #30
For further web SDR decoding please check out message #1065 in the RFI 3965 kHz thread.
