Old 29-10-2018, 06:49   #1
WINB @ 7315 kHz
I'm currently logging this frequency. It's definitely WINB due to its rather unique digital configuration. I don't know if this frequency will be consistently used by WINB or not. Chris recently logged WINB on 7325 kHz at the same time so which frequency is correct? Maybe, both? What a wacky world!
Old 29-10-2018, 07:27   #2
Definitely WINB on 7315 rather than 7325 at the moment - 08:25 UT, Oct 29.
Not sure if this is a change or keying error at the transmitter.
(Switched to 9265 kHz at 09:00 as before).
Old 29-10-2018, 09:07   #3
WINB 7315 Fall Schedule
7315 is correct. Here is our complete fall schedule:
Mon-Fri only: 7315 kHz 062 deg. 0700-0900 UT
9265 kHz 062 deg. 0900-1100 UT
13690 kHz 062 deg. 1100-1700 UT
On weekdays, time between 1700 and first scheduled AM broadcast is occasionally used for transmitter testing on 9265 kHz, often DRM.
Reception reports welcome at winb40th@yahoo.com
Old 29-10-2018, 11:52   #4
Oct 29, 2018 partial log ...
Frequency: +
Modulation: -
Codec: -
Thanks, Hans, for the updated schedule. WINB is currently one of the most prominent digital broadcasters on shortwave as far as time on the air which is nearly 12 hours per day during the week!
BTW, if WINB has authorization to use 7325 kHz as well as 7315 kHz, is WINB planning on using a dual channel consisting of 7310 kHz through 7330 kHz? I'd love to see it!
Old 29-10-2018, 22:55   #5
Well at least that explains why I heard nowt on 15670 kHz today then! :-)
Old 30-10-2018, 08:08   #6
0% decoding in NZ on October 30th
Old 30-10-2018, 10:51   #7
Oct 30, 2018 log ...
Frequency: +
Modulation: -
Codec: -
Old 02-11-2018, 17:44   #8
Frequency: +
Modulation: -
Codec: -
Just 7315 this season, not 7325 khz.
Old 02-11-2018, 20:45   #9
Nov 2nd
0% audio decoded in NZ last night.
Old 05-11-2018, 15:22   #10
Nov 5th, 2018 partial log ..
Frequency: +
Codec: -
Modulation: -
Old 09-11-2018, 15:19   #11
Nov 9th, 2018 partial log ..
Frequency: +
Codec: -
Modulation: -
Old 12-11-2018, 16:42   #12
Nov 12th, 2018 log .. At ~ 0814Z, I switched antennas from the MMDs-31 to my indoor magnetic loop due to an external noise source.
Frequency: +
Codec: -
Modulation: -
Old 13-11-2018, 18:11   #13
Nov 13th, 2018 log ...
Frequency: +
Codec: -
Modulation: -
Old 13-11-2018, 21:07   #14
Partial NZ log from Nov 13. No audio.
Old 14-11-2018, 20:28   #15
Nov 14 in NZ = 0%
