Old 11-03-2019, 17:52   #31
Originally Posted by FritzWue
Strange looking signal, low audio quality at low bitrate.
Hi Fritz,
For an explanation of the strange looking signal please look at this http://www.drmrx.org/forum/showthrea...highlight=winb starting at Message 33.
Old 11-03-2019, 19:01   #32
Hy Zyg,
thank you for the help.
I already found some explanation in the "WINB @ 13755 kHz" thread:
http://www.drmrx.org/forum/showpost....64&postcount=3
Old 12-03-2019, 09:08   #33
The solution against the selfmade interference is a narrow filter.
99% CDA until 07:52 UTC:
Old 12-03-2019, 17:55   #34
"The solution against the selfmade interference is a narrow filter"
If you WANT to listen to RG Stair. Sometimes, silence can be golden so this interference can be handy. I'm partly joking ... partly.
Frequency: +
Codec: -
Modulation: -
Old 12-03-2019, 19:06   #35
In this DRM Software Radio Forum I am commenting on the signal.
Sometimes I better do not care about the content.
Old 16-03-2019, 16:22   #36
Frequency: +
Codec: -
Modulation: -
Old 20-03-2019, 09:12   #37
Frequency: +
Codec: -
Modulation: -
Old 21-03-2019, 15:02   #38
Frequency: +
Codec: -
Modulation: -
The first 15 minutes was logged from my magnetic loop OUTSIDE at ~ 9' from the house and 5' AGL. The remainder of the broadcast was from my MMDs-31. The difference in signal strength between antennas was slightly more than 3 dB.
Old 22-03-2019, 14:33   #39
Frequency: +
Codec: -
Modulation: -
Old 25-03-2019, 10:57   #40
Frequency: +
Codec: -
Modulation: -
Old 26-03-2019, 15:31   #41
Frequency: +
Codec: -
Modulation: -
Old 18-11-2019, 09:06   #42
November 18
Log of WINB 7315 kHz in New Zealand this evening. Good reception until co-channel signal came on at 09:00. 53% audio decoded overall during 0720-1000 UTC.
73 Chris
Old 28-02-2020, 10:12   #43
Not bad but in between there was a visible data transmission ontop:
Old 31-05-2020, 13:34   #44
WINB 7315 kHz
26-May-20
Initially posted in wrong thread.
The overnight reception (from the back of the beam) - 44.52% audio decoded, 17.34 dB max SNR.
Old 31-05-2020, 13:36   #45
WINB 7315 kHz
27-May-20
The overnight reception (from the back of the beam) - 60.93% audio decoded, 17.11 dB max SNR.
