Old 15-09-2019, 12:24   #1
KTWR on 15200 kHZ to South Asia
New freq, new schedule: very strong and very stable signal, max over 30dB.
Robust mode A should be possible. And bit-rate could have reached over 20kbps.
This is the screen shot from kiwiSDR located in kerala, India.
P.S. the dip in the SNR history is network related.
Old 22-09-2019, 01:23   #2
15 Sep. 2019
Max. 4 dB SNR at my location in Japan.
Old 01-06-2020, 04:46   #3
17 May 2020
KTWR DRM English to India logged with FRG-7700 for 29 minutes from 1026-1055 UTC. Max. 10,90 dB SNR and 22,89% decoded audio. Result: Poor reception in Shizuoka, Japan.
Old 01-06-2020, 05:02   #4
24 May
KTWR DRM English to India logged with FRG-7700 for 29 minutes from 1026-1055 UTC. Max. 14,63 dB SNR and 79,30% decoded audio. 11,18 kbps, EEP, aac, Mono, English, Religion, Guam, ID:1003. Mode B/10, 2s, 4/16 QAM, P:0/0, Audio:1 / Data:1, Date/Time: Yes. Audio spectrum: Limited to ~3500 Hz. Slides: Yes, but none decoded.
Old 01-06-2020, 05:06   #5
31 May
KTWR DRM English to India logged with FRG-7700 for 29 minutes from 1026-1056 UTC. Max. 13,39 dB SNR and 9,61% decoded audio. Not good at all this evening in Japan. No slides seen (but they were present).
