Old 22-07-2017, 21:11   #76
Radio Kuwait 15540 kHz Reception near Atlanta, Georgia, USA
This afternoon's reception - due to a local thunderstorm had to start logger later than scheduled - no audio decoded, max SNR about 8 dB.
Old 22-07-2017, 21:41   #77
No signal in Brazil today, 22JUL17. Yesterday, 21JUL17, strong signal: Audio: https://1drv.ms/u/s!AuxxjZ0CDStY0W04Gijlc-nYPH-1
Old 23-07-2017, 10:21   #78
22 Jul 2017 : Radio Kuwait on 15540 kHz from Al Kabd
There was 80% decoded audio during the transmission, 99+% during the second half.
15:00-18:00 UTC Planetary K-index 2+. Local K-index 3.
18:00-21:00 UTC Planetary K-index 2. Local K-index 3.
Planetary A-index: 14. Solar flux: 70. SESC Sunspot number: No data available.
Sunset 20:05 UTC.
Old 23-07-2017, 19:03   #79
Bad signal in Brazil. Pleeeease keep the previous power of 500 kW!!!!
Old 23-07-2017, 21:03   #80
No signal received this afternoon.
Old 24-07-2017, 17:11   #81
23 Jul 2017 : Radio Kuwait on 15540 kHz from Al Kabd
There was 98% decoded audio during the first hour of the transmission, after that it was only 27%.
15:00-18:00 UTC Planetary K-index 3. Local K-index 3.
18:00-21:00 UTC Planetary K-index 2+. Local K-index 3.
Planetary A-index: 16. Solar flux: 69. SESC Sunspot number: No data available.
Sunset 20:04 UTC.
Old 24-07-2017, 20:05   #82
July_24
The signal was very good and gave perfect results as well as 36 dB max SNR, until 18:25. Then the signal dropped and decoding stopped as well. I left the log running hopping the return of the signal, finally I stopped the log at 19:10.
mitajohn is online now   Reply With Quote
Old 24-07-2017, 20:38   #83
July_24
No signal in Brazil. Sad
Old 25-07-2017, 14:11   #84
DRM Service A (Kuwait) logged for 179 minutes from 1801-2059 UTC. The transmission was in English. The first hour was perfect yes, then unstable for half an hour and the rest was so-so. Max. 29.57 dB SNR and 81.57% decoded audio (calculated over the whole log).
Old 25-07-2017, 16:16   #85
24 Jul 2017 : Radio Kuwait on 15540 kHz from Al Kabd
There was 95% decoded audio during the transmission.
15:00-18:00 UTC Planetary K-index 2. Local K-index 3.
18:00-21:00 UTC Planetary K-index 2+. Local K-index 2.
Sunset 20:03 UTC.
Old 25-07-2017, 20:26   #86
July_25
20:25, very weak or no signal here.
Old 25-07-2017, 20:35   #87
July_25
The first hour it's the best in Brazil! Strong signal at 18:20 UTC. Congratulations!
Video: https://youtu.be/kZrvjr4WM5Q
Old 25-07-2017, 21:03   #88
This afternoon's reception - no audio decoded, max SNR 10.67 dB.
Old 26-07-2017, 18:47   #89
25 Jul 2017 : Radio Kuwait on 15540 kHz from Al Kabd
There was 99% decoded audio up until 19:20 UTC, after that it was 65%.
15:00-18:00 UTC Planetary K-index 2-. Local K-index 2.
18:00-21:00 UTC Planetary K-index 2. Local K-index 2.
Planetary A-index: 12. Solar flux: 70. SESC Sunspot number: 12.
Sunset 20:01 UTC.
Old 26-07-2017, 20:23   #90
July_26
MER MAX: 15dB. No decoding. Please MSC 16QAM!!
