Old 27-04-2012, 20:40   #46
Good results except for a break around 1930 UTC. The audio needs some improvement, a change to a higher bitrate and Mode B would be good. Max SNR was 27.9 dB and 99.84% CDA.
Old 30-04-2012, 20:11   #47
Good reception but bitrate and audio quality too low.
15 to 17 kbps should be possible.
Old 30-04-2012, 20:16   #48
Ant-SWL
Ant-SWL's Avatar
First log on this frequency. QTH nr munich.
73, Andy
Ant-SWL is offline   Reply With Quote
Old 04-05-2012, 20:12   #49
May 04
Terrible doppler, again.
Old 08-05-2012, 20:12   #50
Reception was very good here today!
Doppler was down at 1 Hz and SNR very stable at 29 dB.
There was hardly any fading, the signal always was within a 5 dB window!
The only problem is that the sound quality at 9 kbps is worse than with AM!
With todays signal mode B at 15 kbps should be possible!
These little dropouts were TX related.
I wonder why the shorttime frequency stability is so bad.
Old 09-05-2012, 20:09   #51
Good rf signal, bad audio quality, bitrate too low.
Old 09-05-2012, 21:50   #52
Fully agree with Friedrich.
Old 16-05-2012, 22:50   #53
ianf
15120 Voice of Nigeria test
Very strong signal on Newstar With Degen MS 31 in SW UK. Very poor audio quality though, they need to feed TX with good a signal
Old 18-05-2012, 06:27   #54
Strong signal, high SNR, perfect decoding and the Doppler wasn't too high last night, but the 9.1 kbps is a disaster. The audio quality is a catastrophe.
Old 18-05-2012, 20:29   #55
Nice strong signal this evening too. The Newstar DR111 arrived this morning, so I let it play on the same frequency as Dream this evening. There were no drop-outs that I can recall. I need to look into the different features and get used to the controls... I wrote to VoN and they replied that they were going to look into the matter regarding the 9 kbps bitrate and perhaps dare to fiddle with the controls a bit. We can only hope that they increase the bitrate. The audio in the DR111 was pretty muffled (but that was not a problem with the Newstar!)
Old 20-05-2012, 08:30   #56
I was away. The log was unattended. Were they on air? Or did they try out another configuration?
Old 21-05-2012, 21:26   #57
The log from this evening. Same configuration. Same dreadful tone quality.
Old 22-05-2012, 20:12   #58
Ant-SWL
Ant-SWL's Avatar
Unattended log. First log with indoor antenna. Good result...
73, Andy
Old 22-05-2012, 20:43   #59
According to an e-mail from VoN this evening they said that they were going to use 14 kbps and Mode B and asked me to report, but at least after I read the mail there was no change in the transmission parameters...
Added May 23: It was Mode B but still 9 kbps...
Old 23-05-2012, 20:28   #60
According to an e-mail from VoN last night they said that I was late last night and that they had switched back to the "normal" mode before I logged.
Tonight they used Mode A .... but still 9 kbps...
