Old 23-04-2018, 04:54   #61
I listened to about 10 minutes and the result was very good with few periods of silence at 16 QAM. In comparison to the BBC's recent broadcast to the DRM's GA which barely could be received at 50% in parts of Spain near the center of the beam and from a relatively short distance, this broadcast from RRI was received fairly consistently at a relatively long distance. Consistency in decoding should be the primary goal of every digital SW broadcaster. At times, I think some DRM SW broadcasters are really narrowcasters. Maybe, those DRM SW narrowcasters in love with 64 QAM modulation should modulate a high-powered laser beam instead.
Also important, your receiver is much more typical of the average listener than the more expensive and elaborate setups of some members on the DRMRX forums, including myself.
Surely this my "kit DRM" composed of the receiver Avion and the antenna active Sony an-lp 1, are more simple compared to efficient SDR and the antenna wellbrook ALA for example. However, I guarantee the flexibility you can listen emissions in places with lower incidence of interference electrical, as parks and on the inside. So, I know perfectly that the spread is the factor predominant for decoding. in addition, I tried to listen here, but I don't have caught nothing else, such as RNZI 11690, RRI 9535, BBC tests, Kuwait DRM, etc. so, this issue in 11650 of RRI has been the only issue effective in Southern Brazil, but it has days arrives and other non reaches decode. regret the broadcasters still use modulation 64-QAM, which is desperate, because you think will decode, but need a very high gain greater what you think to achieve hear. only in years with spread very good, that modulation is interesting. When I was in London (Dec 2017), had days that wasn't decoding RRI in English for Europe, but with the same gain in 16-QAM could listen perfectly. Anyway, I think 16-QAM should always be the option to the shortwave. if you want to transmit Journaline, then should use the Mode A with 16-QAM.
Modes B and C, you can not transmit journaline with audio, but at least the listener wouldn't be so anxious to listen to the issue as occurs in 64-QAM.
Clint 73!
Old 23-04-2018, 20:25   #62
Clint 73!
Agreed. A portable setup certainly has its advantages since it allows a resident of a city to escape the noise when necessary. Not everyone wants the expense and burden of living in the country. Yes, even Mode A works quite well on shortwave with minimal hops. I give credit to RRI for listening to you and to yourself for the effort.
Old 23-04-2018, 23:25   #63
RRI, 11650 kHz, Reception near Atlanta, Georgia, USA
This evening's report - 0.01% audio decoded, 8.63 dB max SNR.
Old 24-04-2018, 01:43   #64
RRI 11650 kHz DRM in South Brazil 23 APR 18
Decoding any signal at 21:00 - 21: 05 UTC only.
Old 24-04-2018, 01:45   #65
Surely, now only need to work with the AAC+ codec to stay 100% )
Clint 73!
Old 24-04-2018, 23:35   #66
This evening's report - no audio decoded, 8.33dB max SNR.
Old 25-04-2018, 23:29   #67
This evening's report - 2.70% audio decoded, 11.56 dB max SNR.
Old 27-04-2018, 23:24   #68
RRI 11650 kHz DRM in South Brazil 27 APR 18
Strong signal today, decoding until 21:45 UTC. 16-QAM is too good 😁
Old 27-04-2018, 23:34   #69
This evening's report - no audio decoded, 10.28 dB max SNR.
Old 29-04-2018, 00:46   #70
This evening's report - 0.50% audio decoded, 10.93 dB max SNR.
Old 29-04-2018, 06:01   #71
RRI 11650 kHz DRM in Brazil - 28 APR 18
Excellent DRM signal in Brazil: https://youtu.be/DaI2dyIuh7k
Old 29-04-2018, 23:47   #72
This evening's report - 5.32% audio decoded, 13.59 dB max SNR.
Received audio bandwidth showing a tad over 3 kHz (2nd attachment).
Old 30-04-2018, 15:41   #73
RRI 11650 kHz DRM in Lorena - SP, Brazil - 29 APR 18
Full Program!! 👏👏👏
https://youtu.be/G-YfO8DtfX8
https://youtu.be/y5JPKry2JBI
Old 30-04-2018, 23:32   #74
This evening's report - 0.23% audio decoded, 9.91 dB max SNR.
Old 02-05-2018, 00:28   #75
This evening's report - no audio decoded, 9.23 dB max SNR.
