Old 27-03-2019, 23:48   #1426
Frequency: +
Codec: -
Modulation: +
Although this comment has little to do with VoN specifically, it applies generally to most SW broadcasters. Equalize your sources for the supplied bandwidth! Due to limited bandwidth, use SBR regardless of modulation! I'm tired of unbalanced, boomy bass in limited bandwidths whether analog or digital.
Old 29-03-2019, 07:38   #1427
Good reception, audio often not good:
Old 30-03-2019, 15:06   #1428
Frequency: +
Codec: -
Modulation: +
Old 01-04-2019, 09:46   #1429
Frequency: +
Codec: -
Modulation: -
Old 03-04-2019, 18:12   #1430
Strong signal here, but so much transmitter dropouts that I stopped logging.
Without the signal you can see and hear CRI in AM strong on 15125 kHz.
-73 dBm = S9
Old 09-04-2019, 16:48   #1431
Today's staff did not learn how to tune a transmitter and set the audio level.
Intermodulation was only about 20 dB down spoiling SNR
and about +/- 100 kHz of the band.
Further more the audio level was set too low.
I stopped logging for these reasons.
Old 10-04-2019, 16:50   #1432
April_10
A short log. ~97% CDA, 19dB max SNR. After the end of transmission WINB appeared.
Old 10-04-2019, 18:11   #1433
April_10
Another log for 50 mins until the signal turned weak and full of dropouts.
Old 11-04-2019, 18:06   #1434
Intermodulation is about 30 dB down today but the audio level is still too low.
Old 13-04-2019, 18:20   #1435
I think this is a little SNR from VoN.
Old 15-04-2019, 19:15   #1436
Unattended log, looks like there were some transmitter dropouts:
Old 15-04-2019, 20:27   #1437
April_15
Unattended log. There were some TX breakdowns(?). 89% CDA / 24.8dB max SNR.
Old 21-04-2019, 18:07   #1438
Some irregular reception problems maybe caused on my side?
Old 22-04-2019, 21:52   #1439
Frequency: +
Codec: -
Modulation: +
A wee bit of a signal, better than usual at my current location.
