Old 13-01-2006, 18:43   #31
F5NSL
13Jan - 3965 - 12h40-18h00
And here is this afternoon log - unattended. 73's Eric
Eric, Nr Bordeaux, France
Now using Morphy Richards 27024 V1.12.0.0
Previously : Sangean ATS909 + dipole 2x10m & Sat Schneider external mixer - TP570E
F5NSL is offline   Reply With Quote
Old 13-01-2006, 19:13   #32
Looks bad, but sounded nearly perfect this afternoon, as we know from DRMSWR logs.
Old 14-01-2006, 08:38   #33
good until 8:00 then daylight attenuation too high. Signal in
the beginning 40 ÁV after 8:00 below 5 ÁV.
Old 15-01-2006, 11:18   #34
Bob
Very similar to Bernd - good reception for about 1 hour until 08:00.
regards
Bob
Winradio G303Pro, RCA AR-88D/Sat-Service Schneider LC mixer, plus Wellbrook LA5030 Indoor Loop, longwire antenna
Bob is offline   Reply With Quote
Old 15-01-2006, 14:15   #35
Salut Jacques, all,
rather good last night until 03:00, see attachment
Old 15-01-2006, 21:16   #36
conditions down shortly after 8:00 yesterday and today.
Old 15-01-2006, 21:49   #37
... and pretty good until 2000 this evening, see attachment
Old 19-01-2006, 06:10   #38
Salut Jacques, all,
many dropouts last night, no reception from 0400, see attachment
Old 19-01-2006, 23:24   #39
F5NSL
19jan - 3965 - 7h05-8h20
Better SNR obtained by having today receiver on batteries...
Old 19-01-2006, 23:25   #40
F5NSL
19jan - 3965 - 08h25-11h50
morning log - unattended.
Old 20-01-2006, 07:42   #41
Too many switched power supplies around the house and other domestic QRM on this frequency unfortunately, at least with the antenna strung over the roof. Therefore there was no decoded sound. The screen shot was taken on 19th January just after 0700UTC.
Old 20-01-2006, 16:32   #42
Changed the antenna location...
What a difference a change in the location of the antenna made! But HCJB on 3955 kHz killed ISSOUDUN at 1600 UT.
Surprisingly good reception for such low power over a pretty good distance.
73
Old 20-01-2006, 16:45   #43
GRUSON
Hi Simone, Eric, Terje, Bob, Bernd and all...
Thank you for your reports, not bad for "QRP" from Issoudun; could be better with 200 kW like DW but this is not for tomorrow...!
I can see on my side that propagation is not the same from one day to an other but Drm reception is Paris is not easy between about 11:00 and 15:00 UTC despite the low bit-rate but if we add some dB, it could be OK (more power...). I am a bit surprised by the european coverage (Germany, UK, Swiss...)
Regards / 73.
Jacques Gruson
GRUSON is offline   Reply With Quote
Old 20-01-2006, 21:15   #44
Bob
Obviously not great reception at this distance but some quite good periods (log is from 23:20 to 18:00 tonight).
regards
Bob
Old 21-01-2006, 10:47   #45
Hi Jacques,
some results fromthis morning. Signal dropped from S9 to S5-S7. That is still enough for good decooding, but the local interference causes some dropouts.
