Old 21-01-2006, 12:09   #46
Salut Jacques
The same segment as Carsten's in Switzerland, just for comparison. Just now at 1310 UT there is no decoding and the S-meter rests around S2.
73
Old 21-01-2006, 13:15   #47
Bob
For comparison from the UK here is a segment covering the same time as Carsten and Terje.
regards
Bob
Winradio G303Pro, RCA AR-88D/Sat-Service Schneider LC mixer, plus Wellbrook LA5030 Indoor Loop, longwire antenna
Bob is offline   Reply With Quote
Old 21-01-2006, 17:26   #48
Jan. 21
Not much audio in Munich.
Old 21-01-2006, 17:58   #49
Quite good listening this eveening, but some interference from very strong signal on 3955khz.
Old 21-01-2006, 19:54   #50
Salut Jacques,
not so good today, see attachment
Old 21-01-2006, 21:05   #51
690 minutes
Hi Jacques,
Here's 690 minutes logging...
Approx. S-meter readings:
0825: S5-6
0930: S3-5
1130: S2
1515: S5
1715: S8-S9+5 dB
All UTC.
Terrible QRM from 3955 kHz at (at least) at 1730 and 1745 UTC.
73
Old 21-01-2006, 22:19   #52
Jan. 21
Rather bad over here in Munich.
Old 22-01-2006, 08:46   #53
night log
Hi Jacques,
most times quite good this night.
Old 23-01-2006, 19:38   #54
Results from last night.
Old 27-01-2006, 19:42   #55
Salut Jacques, all,
not too bad in Germany today, see attachment
Old 28-01-2006, 12:46   #56
Quite good until 3 UTC last night.
Old 28-01-2006, 12:49   #57
It started at 6.37 UTC this morning. Then quite good.
Old 28-01-2006, 19:00   #58
Quite OK this evening.
Old 28-01-2006, 19:54   #59
Salut Jacques, all,
good results for 3 hours last night, similar to Carstens report
Old 29-01-2006, 07:44   #60
You can't believe it. A weak signal from an 1 kW TX for France received here! Apart from the LoFi sound, it sounded better than it looks in the log.
John.
PS. I cannot explain why DRMSoft handles better the signal than Dream.
mitajohn is online now   Reply With Quote
