Old 01-11-2014, 00:10   #1
Babcock DRM 9760 kHz from Woofferton
With the start of B14, I thought it was a good idea to start a new thread rather than continue with the old thread title of '9850, 9770,9760,9750, 9660 kHz Babcock/VT Digital/ Radio Prague Rampisham/ Woofferton'
This is the first time I have received the NHK transmission.
Sorry I did not make a note of the solar indices.
200 km MUF: 11.7 MHz @ 11:00, 12.0 MHz @ 12:00 UTC.
Old 01-11-2014, 13:53   #2
Nov_01
The last 15 mins, ~98.8%CDA.
Old 08-11-2014, 10:41   #3
Mikey
Disappointing result. Only 62% decoded
Old 08-11-2014, 20:55   #4
7 Nov 2014 : NHK World via Babcock from Woofferton 9760 kHz
83% decoded audio.
09:00-12:00 UTC Planetary K-index 3. Local K-index 3.
Planetary A-index 9. Solar flux 136. Sunspot number: 107.
200 km MUF: 13.0 MHz @ 11:00, 13.8 MHz @ 12:00 UTC.
Old 08-11-2014, 21:37   #5
8 Nov 2014 : KBS World via Babcock from Woofferton 9760 kHz
Like Mike I found today's transmission poor with only 77% decoded audio.
I forgot to put my DR111 into expert mode, so at the beginning of the transmission my DR111 kept on seeking 6135 & 7265 kHz as alternative frequencies!
09:00-12:00 UTC Planetary K-index 1. Local K-index 1.
Planetary A-index 12. Solar flux 146. Sunspot number: 96.
200 km MUF: 10.4 MHz @ 11:00, 11.4 MHz @ 11:30 UTC.
Old 15-11-2014, 06:50   #6
14 Nov 2014 : NHK World via Babcock from Woofferton 9760 kHz
93% decoded audio.
09:00-12:00 UTC Planetary K-index 2. Local K-index 2.
Planetary A-index 5. Solar flux 154. Sunspot number: 104.
Old 15-11-2014, 10:59   #7
15 Nov 2014 : KBS World via Babcock from Woofferton 9760 kHz
93% decoded audio.
Planetary A-index 12. Solar flux 161. Sunspot number: 117.
Old 21-11-2014, 20:20   #8
21 Nov 2014 : NHK World via Babcock from Woofferton 9760 kHz
89% decoded audio.
09:00-12:00 UTC Planetary K-index 2. Local K-index 1.
Planetary A-index 11. Solar flux 168. Sunspot number: 83.
Old 22-11-2014, 10:34   #9
Not good propagation .CDA 84.26% ok.
Old 22-11-2014, 14:29   #10
Even worse at my place. Not even 49% decoded audio. I tested the DR111 too and got 28 logs of nothing. AFS made the DR111 look for alternative frequencies all the time.
Old 22-11-2014, 22:09   #11
22 Nov 2014 : KBS World via Babcock from Woofferton 9760 kHz
89% decoded audio.
Planetary A-index 15. Solar flux 163. Sunspot number: 68.
Old 28-11-2014, 18:19   #12
28th Nov.
60% decoded audio from NHK. At the end China was on the frequency when WOF switched off. If this ruined the transmission is hard to tell, as there are no other transmissions listed in the HFCC table at this time.
Old 28-11-2014, 18:56   #13
28 Nov 2014 : NHK World via Babcock from Woofferton 9760 kHz
99% decoded audio.
Planetary A-index 8. Solar flux 179. Sunspot number: 155.
Old 29-11-2014, 10:34   #14
Nov_29
A late log start. The last 5 mins at ~99% CDA.
Old 30-11-2014, 05:35   #15
29 Nov 2014 : KBS World via Babcock from Woofferton 9760 kHz
87% decoded audio.
09:00-12:00 UTC Planetary K-index 0. Local K-index 1.
Planetary A-index 5. Solar flux 181. Sunspot number: 166.
