Old 05-06-2016, 05:27   #16
4 Jun 2016 : RRI on 7330 kHz from Tiganesti
Plot shows the English and then the German service.
22% decoded audio of the English service during the transmission.
03:00-06:00 UTC Planetary K-index: 1. Local K-index: 2.
06:00-09:00 UTC Planetary K-index: 1. Local K-index: 1.
Planetary A-index: 4. Solar flux: 83. SWPC Sunspot number: x.
Sunrise 03:49 UTC.
Old 05-06-2016, 06:32   #17
June_05
Both services. The 1st half was much better than 2nd half.
mitajohn is online now   Reply With Quote
Old 06-06-2016, 07:12   #18
June_06
Both services. This time the 2nd half was better than the 1st one although the SNR reached 32.8 dB near its end.
Old 10-06-2016, 06:51   #19
June_10
Similar erratic decoding both parts. During the 1st part a TX breakdown at ~05:45 took place as well as the regular (~every 5 mins) local QRM which seem to be part of my plots now.
Old 11-06-2016, 06:34   #20
June_11
A late start, only the 2nd part. An almost perfect result with the SNR up to 33.5 dB.
Old 12-06-2016, 06:41   #21
June_12
Both services.
The first part was overall bad, only for a period of ~7 mins the results were almost perfect and a peak of the SNR over 30 dB noticed.
The second part was almost perfect with high SNR reached up to 32.4 dB.
Old 13-06-2016, 06:33   #22
June_13
Both services. Similar scenario like the yesterday's one but worse.
Old 20-06-2016, 06:46   #23
June_20
Both services. Unstable signal, 40-60 dBuV, in the 2nd part a lot of decoding errors noticed while the max SNR reached up to 33.6 dB.
Old 24-06-2016, 06:38   #24
June_24
Bad results both services, the 2nd part was a bit better than the 1st.
Old 29-06-2016, 06:36   #25
June_29
Both services. Unstable signal, 40-55 dBuV, in the 1st part the results were bad with lots of decoding errors while the max SNR reached up to 29.9 dB, in the 2nd part the results were much better although with lower max SNR.
Old 10-07-2016, 06:35   #26
July_10
2nd part only. The results were almost perfect until 06:22 when the signal dropped and decoding dropouts started.
Old 15-07-2016, 06:37   #27
July_15
The last mins of the 1st part and all the 2nd part. A lot of dropouts due to fading and the local QRM. The SNR max reached up to 33 dB.
Old 27-07-2016, 07:40   #28
Perfect reception on both transmissions, first the English, then the German.
Old 29-07-2016, 09:19   #29
Newstar DR111
Perfect reception with my Newstar DR111 on both transmissions, first the English, then the German. High SNR.
Old 01-08-2016, 05:34   #30
31 Jul 2016 : RRI on 7330 kHz from Tiganesti
90% decoded audio of the English service during the transmission.
06:00-09:00 UTC Planetary K-index: 1+. Local K-index: 2.
Planetary A-index: 6. Solar flux: 71. SWPC Sunspot number: 13.
Sunrise 04:36 UTC.
