Old 01-08-2016, 07:37   #31
Aug_01
Both services. The RF signal was ~60dBuV. Until ~05:43 the results were very good with max SNR at 28.5dB, then the SNR dropped mostly below 20dB and the results turned very bad.
Old 01-08-2016, 21:15   #32
For the first time in months, I could clearly see the digital signature on the waterfall. Reception should continue to improve markedly over the next week.
Old 19-08-2016, 07:36   #33
Aug_19
Both services. The RF signal was ~60dBuV. Until ~05:56 the results were very good with max SNR at 30.5dB, then the SNR dropped and decoding errors started.
Old 19-08-2016, 23:17   #34
Reception from Europe continues to slowly improve (a bit later than normal) for this time of year, but the odds of decoding anything from RRI is essentially nil.
Old 22-08-2016, 19:42   #35
Reception continues to improve. Due to interference on weekdays, this broadcast is functionally receivable only on weekends in North America. On weekdays, there is an 5 kHz digital signal centered on 7335 kHz which destroys the signal from RRI.
Old 23-08-2016, 22:07   #36
Atmospheric conditions continue to improve for broadcasts from Europe.
Old 29-08-2016, 22:09   #37
Decent reception on weekends when the 5 kHz digital signal centered on 7335 kHz is gone ... Apparently, RRI changes azimuth at 26 minutes after the hour which worsens reception in North America.
Old 29-08-2016, 22:10   #38
Reception during weekdays is generally awful due to the 5 kHz digital signal on 7335 kHz....
Old 26-09-2016, 07:37   #39
Sept_26_EN
The English service, a result at 99.99% CDA and 32.4dB max SNR.
Old 26-09-2016, 07:39   #40
Sept_26_GE
The German service, a result at 100% CDA and 33.4dB max SNR.
Old 27-09-2016, 07:36   #41
Sept_27_EN
The English service, a result at 99.76% CDA and 31.8dB max SNR.
Old 27-09-2016, 07:38   #42
Sept_27_GE
The German service, a result at 99.95% CDA and 33.3dB max SNR.
Old 14-10-2016, 09:40   #43
Logged this station for a while as BBC on 4 MHz was too weak in the aftermath of the solar storm last night. Perfect reception.
The second log was recorded with the Newstar DR111. It is a 76 minutes long log which started with the end of the Galbeni transmission. I believe the SNR is a new record with the DR111.
Old 17-10-2016, 08:07   #44
Perfect reception of the German transmission with the DR111 connected to an external antenna and battery powered by a 5 Ah GP PowerBank.
Old 18-10-2016, 08:13   #45
Perfect reception of the English and the German transmission with the DR111 connected to an external antenna and battery powered from a 5 Ah GP PowerBank.
So far the DR111 has played 5.5 hours on one charge and there are still 3 out of 4 LEDs lighting on the battery indicator.
