Old 16-04-2017, 22:06   #1
RRI on 9535 kHz from Galbeni
Plot shows the French and then the English service.
98% decoded audio of the English service during the transmission.
18:00-21:00 UTC Planetary K-index 1. Local K-index 1-.
21:00-00:00 UTC Planetary K-index x. Local K-index x.
Planetary A-index: 6. Solar flux: 75. SESC Sunspot number: 11.
Sunset 19:01 UTC.
Old 18-04-2017, 08:54   #2
RRI Galbeni TX1 logged for 50 minutes from 2006 UTC. Max. 19.67 dB SNR and 50.44% decoded audio. Probably interference from China 10 kHz down - sounded like Fire-Dragon "music" just after the close-down of RRI.
Old 19-04-2017, 05:07   #3
17 Apr 2017 : RRI on 9535 kHz from Galbeni
92% decoded audio of the English service during the transmission.
18:00-21:00 UTC Planetary K-index 0+. Local K-index 0.
21:00-00:00 UTC Planetary K-index 1-. Local K-index 1.
Planetary A-index: 4. Solar flux: 75. SESC Sunspot number: Data not available.
Sunset 19:05 UTC.
Old 19-04-2017, 22:30   #4
18 Apr 2017 : RRI on 9535 kHz from Galbeni
93% decoded audio of the English service during the transmission.
18:00-21:00 UTC Planetary K-index 1+. Local K-index 2.
21:00-00:00 UTC Planetary K-index 3-. Local K-index 3.
Planetary A-index: 4. Solar flux: 86. SESC Sunspot number: No data available.
Sunset 19:04 UTC.
Old 20-04-2017, 21:31   #5
19 Apr 2017 : RRI on 9535 kHz from Galbeni
82% decoded audio of the English service during the transmission.
18:00-21:00 UTC Planetary K-index 3-. Local K-index 3.
Planetary A-index: 7. Solar flux: 81. SESC Sunspot number: 12.
Sunset 19:05 UTC.
Old 21-04-2017, 21:28   #6
20 Apr 2017 : RRI on 9535 kHz from Galbeni
No signal was received from either the French or the English service.
Old 28-04-2017, 15:32   #7
RRI Galbeni TX1 logged for 52 minutes from 2008 UTC. Max. 22.36 dB SNR and 43.32% decoded audio. Although the log states that there was decoded audio, there was definitely no audio source connected. This could be seen clearly from the Audio Spectrum panel in DReaM. Something wrong somewhere.
Old 29-04-2017, 08:45   #8
RRI Galbeni TX1 logged for 54 minutes from 2001 UTC. Max. 19.70 dB SNR and 72.75% decoded "audio". Although the log states that there was decoded audio, there was definitely no audio source connected, at least not during the first 20 minutes. The rest of the log was unattended. The Audio Spectrum pane in DReaM showed no traces of audio.
Old 15-05-2017, 13:32   #9
RRI Galbeni TX1 logged for 58 minutes from 1958 UTC. Max. 19.65 dB SNR and 60.74% decoded audio. Generally, Galbeni always has low SNR. Very unstable decoding.
Old 03-06-2017, 21:19   #10
About 90% decoding of RRI Galbeni TX1 in French on 9535 kHz right now, (my local) Saturday afternoon, 3 June 2017, 2000-2030 UTC.
St John's, Newfoundland; MR27024 with eight-metre wire strung from my window to my fence.
EDIT: At 2030, switch to English. Closer to 100% decoding at this point.
Old 24-07-2017, 21:41   #11
July_24
MER MAX: 14dB. No decoding sound in Brazil. MSC 16QAM pleeeease!
Old 18-08-2017, 22:19   #12
Any signal in Brazil. MER MAX: 12dB
Old 18-08-2017, 22:50   #13
I saw the signal at my location, but it was so weak that no log was possible.
Old 04-10-2017, 21:39   #14
3 Oct 2017 : RRI on 9535 kHz from Galbeni
18:00-21:00 UTC Planetary K-index 0+. Local K-index 1.
21:00-00:00 UTC Planetary K-index 1. Local K-index 2.
Planetary A-index: 7. Solar flux: 86. EISN Sunspot number: 28.
Sunset 17:36 UTC.
Old 04-10-2017, 23:55   #15
Thumbs down
Sunset 17:36 UTC.
Very good GOSVN. I want see your DRM video from RRI on YouTube!!!
