Old 20-04-2017, 11:27   #1
17790 kHz BBC World Service from Singapore
Here are my two logs from BBC from Kranji, Singapore.
Here is yesterday's result (after a late log start): Logged for 24 minutes from 0846 UTC. Max. 19.32 dB SNR and 69.62% decoded audio.
This morning I logged 55 minutes from 0846 UTC. Max. 22.74 dB SNR and 71.75% decoded audio.
Old 22-04-2017, 08:18   #2
Here is the log from 21st April. Logged for 61 minutes from 0759 UTC. Max. 25.32 dB SNR and 94.46% decoded audio.
Today, 22nd, the propagation is down so there will be no log.
Old 26-04-2017, 07:41   #3
BBC WorldService from Kranji, Singapore, logged for 60 minutes from 0800 UTC.
Max. 14.44 dB SNR and 0.41% decoded audio. Extremely poor propagation conditions.
Old 26-04-2017, 10:47   #4
BBC WorldService from Kranji, Singapore, logged for 63 minutes from 0757 UTC.
Max. 16.11 dB SNR and 1.92% decoded audio. The radio weather is still unsettled.
Old 27-04-2017, 19:44   #5
Miserable propagation this morning. Then DReaM crashed halfway through the transmission. No log.
Old 28-04-2017, 14:41   #6
BBC WorldService from Kranji, Singapore, logged for 61 minutes from 0759 UTC.
Max. 24.45 dB SNR and 76.12% decoded audio.
Old 29-04-2017, 09:26   #7
BBC WorldService from Kranji, Singapore, logged for 52 minutes from 0808 UTC.
Max. 26.01 dB SNR and 76.89% decoded audio.
Old 30-04-2017, 09:21   #8
BBC WorldService from Kranji, Singapore, logged for 61 minutes from 0758 UTC.
Max. 24.96 dB SNR and 85.62% decoded audio. Tuned DR111 to 17790 kHz and pulled out the telescopic antenna. The DR111 produced some sound with 13 dB SNR in the display. At that time the SNR in DReaM was 23 dB.
Old 01-05-2017, 09:28   #9
BBC WorldService from Kranji, Singapore, logged for 63 minutes from 0756 UTC. Max. 27.06 dB SNR and 98.87% decoded audio. Best result on from Kranji so far.
Old 02-05-2017, 09:43   #10
BBC WorldService from Kranji, Singapore, logged for 64 minutes from 0755 UTC. Max. 25.98 dB SNR and 93.89% decoded audio. Not so good as yesterday's result.
Old 02-05-2017, 18:46   #11
I have audio cut, many fading, is great problem, good Journaline, SNR from 13 db to 19,7 db maxi. :
http://nsa37.casimages.com/img/2017/...0529465740.jpg
Old 03-05-2017, 10:02   #12
BBC WorldService from Kranji, Singapore, logged for 63 minutes from 0756 UTC. Max. 23.76 dB SNR and 98.58% decoded audio. The last 30 minutes were unattended.
Old 04-05-2017, 09:21   #13
BBC WorldService from Kranji, Singapore, logged for 61 minutes from 0758 UTC. Max. 28.5 dB SNR and 99.59% decoded audio. Another best result on from Kranji so far. Most of the transmission was unattended.
Old 07-05-2017, 14:43   #14
BBC WorldService from Kranji, Singapore, logged for 62 minutes from 0758 UTC. Max. 26.14 dB SNR and 99.81% decoded audio. Most of the transmission was unattended.
Old 07-05-2017, 15:07   #15
BBC WorldService from Kranji, Singapore. I forgot about the transmission so the log started around 0832 UTC. Logged for 28 minutes from 0832 UTC. Max. 28.15 dB SNR and 99.34% decoded audio.
