Old 02-06-2017, 02:42   #16
Originally Posted by Digger
Whatever wide DRM (or the like) I picked up around 12110 kHz, it was definitely not from the USCG. I got this confirmed today.
Interesting... I'm not so sure. , but it's possible it wasn't the USCG. Who was it, then? I definitely received a 20 kHz digital signal which was centered on 8001 kHz once and the signal was similar in strength to the USCG's DRM broadcast. You received a similar 20 kHz digital signal on 12100 kHz to my mysterious signal on 8001 kHz so I'm suspicious of the USCG's response to you. Coincidentally or not, both of these frequencies are used by the USCG for testing DRM. I wonder if the left knows what the right is doing within our government at times... I never expected such a response from the USCG. One would think the USCG would want to identify who it was if it wasn't them and the USCG would have the capability of discovering the identify of the intruder. Interesting comment, indeed, and thanks for sharing it, but I don't necessary buy the USCG's response to you.
Old 02-06-2017, 20:00   #17
Jun 2nd log ... weak signal, but it was there. Maximum SNR is a spurious result.
Old 03-06-2017, 22:38   #18
Jun 3rd log ... Spurious maximum SNR
Old 04-06-2017, 19:15   #19
Jun 4th log ...
Old 05-06-2017, 21:02   #20
Jun 5th log ...
Old 06-06-2017, 21:28   #21
Jun 6th log ...
Old 07-06-2017, 18:16   #22
Jun 7th log ...
Old 08-06-2017, 19:38   #23
Jun 8th log ...
Old 09-06-2017, 19:57   #24
Jun 9th log ...
Didn't WRMI vacate 6855 kHz? If so, why does the US government tolerate interference from the digital signal on 6845 kHz? Maybe, because the US government is powerless to stop it? LoL
Old 10-06-2017, 08:35   #25
Just for fun I tried a few SDR receivers around the world this morning. There is a DRM signal on 9900 kHz now at 0730 UTC which I saw in Kansas USA, 4200 km, (very weak) and in Alberta CDN, 2400 km, quite strong. There were no traces of signal in Novosibirsk RUS, 6600 km or in Aichi JPN, 5400 km. Needless to say there is no DRM here in Stockholm either on 9900 kHz at 0735 UTC.
Old 10-06-2017, 20:47   #26
Terje,
The signal was quite weak at my location on 9900 kHz so I decided to not even log it. Keep trying, you'll get it again one day.
Old 11-06-2017, 08:43   #27
Tom, we need a small (or large, rather) wonder for that to happen! I cannot even see a trace of the Mr. Overcomer on 9.955 MHz either. However in Alberta in Canada the signal is clearly visible. There is occasional QRM in the channel as you can see in the screenshot.
File Type: jpg 9900khz@0727utc@alberta(cdn)11jun2017.jpg (29.8 KB, 29 views)
Old 15-06-2017, 19:45   #28
Jun 15th log ...
Old 16-06-2017, 20:26   #29
Jun 16th log ...
Old 17-06-2017, 01:00   #30
A DRM waveform visible on 8000 kHz here in NZ, but not much else....
http://www.owdjim.gen.nz/chris/radio/DRM/ http://kiwisdr.owdjim.gen.nz:8073
