Old 10-09-2017, 21:14   #226
Radio Kuwait 15540 kHz Reception near Atlanta, Georgia, USA
This afternoon's reception report - 1.81% audio decoded, max SNR 16.21 dB.
No signal received until about 1942.
Old 11-09-2017, 19:14   #227
10 Sep 2017 : Radio Kuwait on 15540 kHz from Al Kabd
There was 59% decoded audio during the transmission.
15:00-18:00 UTC Planetary K-index 2. Local K-index 2.
18:00-21:00 UTC Planetary K-index 2-. Local K-index 2.
Planetary A-index: 6. Solar flux: 272! EISN Sunspot number: 45.
Sunset 18:29 UTC.
Old 11-09-2017, 21:51   #228
Sunset 18:29 UTC.
Bad signal
Old 12-09-2017, 19:28   #229
11 Sep 2017 : Radio Kuwait on 15540 kHz from Al Kabd
There was 60% decoded audio during the transmission.
15:00-18:00 UTC Planetary K-index 3-. Local K-index 2.
18:00-21:00 UTC Planetary K-index 3. Local K-index 3.
Planetary A-index: 7. Solar flux: 80. EISN Sunspot number: 30.
Sunset 18:26 UTC.
Old 13-09-2017, 08:00   #230
The reception of the English service in Stockholm is always very poor. DRM Service A (Kuwait) in English logged for 65 minutes from 1808-1912 UTC. Very unstable reception and almost no signal after 1830 UTC. Max. 25 dB SNR and 14.38% decoded audio.
Old 13-09-2017, 19:48   #231
12 Sep 2017 : Radio Kuwait on 15540 kHz from Al Kabd
Very poor reception with <1% decoded audio during the transmission!
15:00-18:00 UTC Planetary K-index 2+. Local K-index 3.
18:00-21:00 UTC Planetary K-index 4. Local K-index 4.
21:00-00:00 UTC Planetary K-index 6-. Local K-index 4
Planetary A-index: 11. Solar flux: 80. EISN Sunspot number: 12.
Sunset 18:24 UTC.
Old 13-09-2017, 20:48   #232
Sunset 18:24 UTC.
"Don't worry, be happy" kkk
Old 14-09-2017, 19:50   #233
13 Sep 2017 : Radio Kuwait on 15540 kHz from Al Kabd
The transmission disappeared by 19:30 UTC, during this period there was 39% decoded audio.
15:00-18:00 UTC Planetary K-index 1+. Local K-index 2.
18:00-21:00 UTC Planetary K-index 1+. Local K-index 2.
21:00-00:00 UTC Planetary K-index 0. Local K-index 0
Planetary A-index: 18. Solar flux: 73. EISN Sunspot number: 15.
Sunset 18:22 UTC.
I would be happier if I knew why the reception was so bad, was it propagation conditions or were they running much lower power, you are never quite sure with HF!
Old 14-09-2017, 20:41   #234
Hi Neil,
The answer is time and conditions. Even if propagation was normal the signal starts to decrease in the UK at 1900.
The attached VOAAREA plot (for 1900 UTC September 2017) uses the latest HFCC information which shows R. Kuwait with 250 kW power and a 4/3/0.5 dipole array beaming 310 degrees with a 9 deg slew. I'm assuming that they are running a power of 250 kW analog which is equivalent to 125 kW DRM.
The plot colour code is S7 = pale blue, S8 = pink, S9 = yellow, S9+10 dB = grey and S9+20 dB = white.
It can be seen why Terje has a problem receiving the signal in Stockholm and why Clint does not receive it well in the southern part of Brazil. It does, however, show why Hans in Florida was able to get good decoding.
Hope that helps,
File Type: png Radio Kuwait 15540 kHz 1900 utc Sept 2017.png (99.6 KB, 30 views)
Old 14-09-2017, 21:07   #235
This afternoon's reception report - 1.79% audio decoded, max SNR 16.61 dB.
Old 15-09-2017, 19:59   #236
14 Sep 2017 : Radio Kuwait on 15540 kHz from Al Kabd
There was 81% decoded audio during the transmission.
15:00-18:00 UTC Planetary K-index 6-. Local K-index 4.
18:00-21:00 UTC Planetary K-index 5-. Local K-index 5.
21:00-00:00 UTC Planetary K-index 4+. Local K-index 5
Planetary A-index: 15. Solar flux: 73. EISN Sunspot number: 12.
Sunset 18:19 UTC.
Many thanks for the VOACAP plots, I always appreciate them. I can understand why the signal disappears after sunset, the main factor that I could not understand was why the signal was so bad on the 12th September. The reception was even better on the 8th September when there was the radio blackout! Geomagnetic and other solar indeces were similar on both the 12th and 14th September, but there was a hugh difference in the reception of Radio Kuwait on those two days.
Old 15-09-2017, 21:25   #237
My speculation, for what it's worth, is that the main thing that happened on Sept 12 was a coronal mass ejection (CME) that gave a glancing blow to the earth during the broadcast. Conditions were already relatively poor at the time and the CME just made things worse.
This afternoon the signal, here in the Atlanta area, was non-existant for most of the time.
Next month, even with normal propagation, the signal path will not be there for much of the transmission period. I wonder if Radio Kuwait will change frequency?
Old 15-09-2017, 23:45   #238
I send them an e-mail, but they didn't answer me : ((
Old 16-09-2017, 19:47   #239
15 Sep 2017 : Radio Kuwait on 15540 kHz from Al Kabd
No signal was received.
15:00-18:00 UTC Planetary K-index 3+. Local K-index 4.
18:00-21:00 UTC Planetary K-index 5+. Local K-index 5.
21:00-00:00 UTC Planetary K-index 5-. Local K-index 4
Planetary A-index: 25. Solar flux: 72. EISN Sunspot number: 13.
Sunset 18:17 UTC.
Thanks Zyg for your theory about propagation on the 12 September, a lower frequency would certainly seem like a good idea for B17.
Old 16-09-2017, 21:08   #240
Almost no signal this afternoon.
