Old 16-07-2017, 18:26   #1
DRM Hdn
DRM Hdn's Avatar
13650 kHz DRM Service A
Hello, found at 17:15 UTC this frequency with DRM Signal
No tone with DreaM and Sodira at the moment but with Multyradio.
Old 16-07-2017, 18:58   #2
DRM Hdn
DRM Hdn's Avatar
Here a first screenshot from this station.
Is it from Japan or from Korea?
Old 16-07-2017, 19:46   #3
Same configuration as Kuwait though... The signal is too weak here in Stockholm at 1846 UTC. Too high Kp and too much Aurora. The 0.00 kbps could indicate that they transmit xHE-AAC? I'll check again tomorrow.
PS:
Now at 1953 UTC they run 17 kbps and AAC+ and it looks exactly the same as on 15 MHz.
PPS:
Fragments of a female announcer at 1901 UTC in Arabic (most probably)
Old 16-07-2017, 21:03   #4
It really looks like 15540 KHz even the -300Hz offset is there.
Audio is less interesting as not in English and less music
Old 16-07-2017, 21:17   #5
DRM Service A (Kuwait) logged for 60 minutes from 1908-2007 UTC. The QRG is normally not allocated to Kuwait as far as I could look up. The transmission was in Arabic and the origin was definitely Kuwait. Max. 26.10 dB SNR and 22.08% decoded audio (in DReaM). Kp suddenly rose to 6 during the day and strong Aurora made the reception difficult here.
PS: The TX Site has been changed to Al Kabd
Old 17-07-2017, 12:17   #6
16 Jul 2017 : Radio Kuwait on 13650 kHz from Al Kabd
I decoded 20% audio of the Arabic transmission. In notice the same UTC +3 hours time offset as the 15540 kHz transmission
Old 17-07-2017, 19:17   #7
July 17
After some struggle, after Win10-update I got some good sound from Kuwait.
20 minutes of listening with a CDA of 99.1 %. Good audio, although I didn't understand it..
Time: 17:44-18:04 UTC
Old 17-07-2017, 20:54   #8
July_17
A 161 mins log (I stopped the log when the decoding almost stopped). This seems to be a transmission from Kuwait. The tune at the hour is the same as on 15540kHz transmission, same configuration, language Arabic. 98.55% CDA / 33.6dB max SNR. Missing are the TX site and the target area.
EDIT: The transmission ended at 20:00.
Old 17-07-2017, 21:20   #9
@ John: I updated the TX Sites. Get it from my web. It is Al Kabd.
Perfect reception for 85 minutes. The target area seems to be USA. I monitored 15 MHz as well, therefore the log is short. Max. 29.92 dB SNR, average 27.91 dB SNR and 100.0% decoded audio.
Old 17-07-2017, 22:39   #10
The target area should be North America since coverage of Europe would be sufficient also. Since the loss of regional DRM transmitters such as Sackville and Cariari, North America could use additional DRM broadcasters.
I monitored both 15540 kHz and 13650 kHz briefly today and was surprised to see anything at all. 13650 kHz seems to be slightly superior to 15540 kHz at my location. I'll continue to look periodically.
Old 18-07-2017, 16:53   #11
17 Jul 2017 : Radio Kuwait on 13650 kHz from Al Kabd
There was 30% decoded audio during the transmission.
15:00-18:00 UTC Planetary K-index 5. Local K-index 4.
18:00-21:00 UTC Planetary K-index 1+. Local K-index 2.
Planetary A-index: 41. Solar flux: 86. SESC Sunspot number: 26.
Sunset 21:11 UTC.
Old 18-07-2017, 19:39   #12
July_18
A 90 mins result at 99.25% CDA / 33dB max SNR.
Old 18-07-2017, 19:50   #13
July 18
70 minutes of Kuwait this evening. Great reception, but the "program" could be better...
Time: 17:31-18:42 UTC which resulted in 99.55 CDA.
Old 19-07-2017, 19:13   #14
July_19
A result for 66 mins at 99.8% CDA / 31 dB max SNR.
Old 20-07-2017, 21:04   #15
July_20
A short but perfect log, the last 13 mins of the transmission, 32.6 dB max SNR.
