Old 21-07-2017, 18:19   #16
July_21
A 65 mins result at 99% CDA / 30.8 dB max SNR.
mitajohn is online now   Reply With Quote
Old 22-07-2017, 07:57   #17
DRM Service A (Kuwait) logged for 179 minutes from 1700-1959 UTC. In Arabic. Splatter from China 10 kHz down during the first 55 minutes. Max. 30.03 dB SNR and 99.12% decoded audio.
Old 23-07-2017, 18:50   #18
July_23
A result for 103 mins at 99.7% CDA & 32.6dB max SNR.
Old 25-07-2017, 20:23   #19
July_25
A mostly unattended log. 99.8% CDA / 34.7dB max SNR for 165 mins.
Old 26-07-2017, 08:22   #20
25th July
DRM Service A (Kuwait) logged for 164 minutes from 1716-1959 UTC in Arabic. Again interference from China during the first 40 minutes in the log. Max. 29.87 dB SNR and 98.90% decoded audio.
Old 27-07-2017, 19:36   #21
July_27
A result for 127 mins at ~99.7% CDA & 33.4dB max SNR.
Old 29-07-2017, 18:11   #22
July_29
A result for 60 mins. After ~17:32 the signal started dropping slowly out and decoding errors started. 99% CDA / 32.4dB max SNR.
Old 31-07-2017, 07:22   #23
30th July
DRM Service A (Kuwait) logged for 178 minutes from 1701-2000 UTC. In Arabic. The usual CRI splatter in the beginning, worst during the first 30 minutes. Max. 30.38 dB SNR and 99.42% decoded audio.
Old 31-07-2017, 18:16   #24
If you're in North America, today should be a good time to log 13650 kHz. I'm receiving a weak signal in the central USA, but it's a least visible while 15540 kHz is not.
Old 01-08-2017, 07:59   #25
31st July
DRM Service A (Kuwait) logged for 61 minutes from 1743-1844 UTC. In Arabic. For some reason the transmission started late around 1742 UTC. A local problem caused a drop-out at 18:35 UTC. Max. 29.41 dB SNR and 99.58% decoded audio.
Old 03-08-2017, 07:43   #26
DRM Service A (Kuwait) logged for 155 minutes from 1725-1959 UTC. In Arabic. I started the log late. Perfect reception with perfect decoding. Max. 29.85 dB SNR and 100.00% decoded audio.
@MOI Kuwait: Please run a transmission with the xHE-AAC again!
Old 05-08-2017, 22:53   #27
August_05
Good signal in Brazil. Around 17dB MER.
Video: https://youtu.be/a8mNye6Pt9A
Old 07-08-2017, 18:58   #28
Aug 7th, 2017 partial log as I got bored when the signal faded, ahem MSC of 16 QAM please. Anyway, the signal began to recover somewhat later, but I decided to not log it further.
Furthermore, I'd like to see a DRM broadcast closer than 6,000 MILES away from my location in NA without having to move ... This one is nearly the same distance as those former DRM broadcasts originating in Australia...
Old 08-08-2017, 20:59   #29
Aug 8th, 2017 partial log ... better late than never, I suppose.
Old 09-08-2017, 09:14   #30
DRM Service A (Kuwait) logged for 156 minutes from 1723-1959 UTC. In Arabic. For some reason the transmission started late (again) around 1722 UTC. Max. 31.07 dB SNR and 99.97% decoded audio.
As there is no personnel from Ampegon on location in Kuwait, the chances are almost zero that someone would dare or try change the DRM configuration.
