Old 09-08-2017, 20:04   #31
Aug_09
A 90 mins result at 99.95% CDA / 30dB max SNR.
Old 09-08-2017, 20:25   #32
Aug 9th, 2017 partial log ... I had to use a noisy 18v laptop charger near the end of the log ..
Old 10-08-2017, 22:40   #33
Aug 10th, 2017 log ...
Old 11-08-2017, 22:30   #34
Aug 11th, 2017 partial log ... first hour was likely the best and missed.
Old 12-08-2017, 23:22   #35
Aug 12th, 2017 log... The first hour definitely was NOT the best in this atypical transmission due to marginal propagation over the past 24 hours or so.
Old 13-08-2017, 23:06   #36
Aug 13th, 2017 partial log with first hour missing again along with atypical results.
Old 14-08-2017, 08:40   #37
DRM Service A (Kuwait) logged for 178 minutes from 1702-1959 UTC. In Arabic. Max. 30.14 dB SNR and 99.87% decoded audio.
Old 14-08-2017, 20:31   #38
Kuwait logged with the Gospell GR-216
DRM Service A (Kuwait) logged for 108 minutes from 1712-1900 UTC. In Arabic. A mostly unattended log. Max. 32.00 dB SNR and 99.72% decoded audio.
My first log with the Gospell GR-216. The latest firmware 411M allows the GR-216 to log DRM Broadcasts to a USB Stick. During the DRM broadcast, just insert the USB stick and the log starts automatically. End the log simply by switching to AM. At present the log contains Audio and SNR. The log was taken with an external antenna.
Old 14-08-2017, 21:57   #39
Honestly, I hope the logging is more robust than the DR-111. I appreciate your work with Gospell, Terje. The GR-216 needs to be absolutely rock solid in operation before mass production.
Old 14-08-2017, 21:59   #40
Aug 14th, 2017 log ...
Old 17-08-2017, 23:10   #41
Aug_17
A partially unattended log.
Old 18-08-2017, 22:54   #42
Aug 18th, 2017 partial log ... not much since the engineers fiddled with their configuration.
Old 20-08-2017, 02:01   #43
August_19
Good signal in Brazil.
Vídeo: https://youtu.be/NQ4oDzytHgY
Old 22-08-2017, 19:59   #44
Aug 22nd, 2017 partial log ...
Old 24-08-2017, 20:36   #45
Aug 24th, 2017 partial log ...
