Old 25-08-2017, 19:33   #46
Aug 25th, 2017 partial log due to other higher priorities.
Old 26-08-2017, 21:39   #47
Aug 26th, 2017 partial log, i.e. first two hours. It's really unfortunate that all DRM SW broadcasts don't use 16 QAM modulation for the MSC and this log along with numerous others illustrates why.
Old 27-08-2017, 21:57   #48
Aug 27th, 2017 partial log, i.e. first two hours.
Old 28-08-2017, 20:28   #49
Aug 28th, 2017 partial log, i.e. first two hours.
Old 29-08-2017, 21:16   #50
Aug 29th, 2017 partial log, i.e. first two hours.
Old 30-08-2017, 22:56   #51
Aug 30th, 2017 partial log, i.e. first two hours. After changing their configuration, am I remotely near the center of the beam on either frequency? I doubt it.
Old 31-08-2017, 02:54   #52
What's the change? Bad signal in Brazil, I had listen it with 27dB!
Old 31-08-2017, 14:49   #53
I'm not sure, but I suspect a change in configuration of the antenna. The change has been consistently noticeable and not a mere of reflection of propagation in my opinion. I can't prove this assertion, however.
Old 31-08-2017, 16:23   #54
I believe in it. Here I had 27dB! Now only 15
Old 31-08-2017, 17:21   #55
Aug_31
The signal here turned very weak, no log.
Old 31-08-2017, 19:45   #56
Aug 31st, 2017 partial log, i.e. first hour. Propagation clearly was abnormal.
Old 01-09-2017, 23:00   #57
Sep 1st, 2017 partial log , i.e. ~ first two hours.
Old 05-09-2017, 18:41   #58
Sept_05
When the signal appeared I started the log, it lasted about 17 mins then the signal lost.
Old 06-09-2017, 20:24   #59
DRM Service A (Kuwait) in Arabic logged for 31 minutes from 1831-1901 UTC. Max. 32 dB SNR and 98.35% decoded audio.
Old 06-09-2017, 21:05   #60
Only you there in Greece are listening well to this Digger kkk
