Old 27-08-2019, 00:03   #16
Originally Posted by DRM Hdn
I followed this signal via kiwi-sdr. . . .
Hallo!
Which receiver was that?
Gruss,
Old 27-08-2019, 06:09   #17
DRM Hdn
DRM Hdn's Avatar
it was the Daegu City/South Korea SDR Station via SDR.hu
Regards from Elbflorenz,Saxony
DRM Hdn is offline   Reply With Quote
Old 27-08-2019, 10:14   #18
DRM Hdn
DRM Hdn's Avatar
3560kHz
The todays frequency monitoring results:
It looks like they're playing with the Dream Transmitting software.
Audio was short decodable on 9/4,5kHz Modus
The Pictures are too big for upload.
Old 27-08-2019, 10:45   #19
DRM Hdn
DRM Hdn's Avatar
the pictures
the pictures:
Old 27-08-2019, 11:30   #20
3560 kHz 27rd Aug. 2019
It sure looks like they're playing aroun with the Dream TX. I was listening at my home in Shizuoka City and I noticed that they used 4.5 kHz BW. They also used 400 ms interleaver which has never been any good for the decoding. In the beginning the signal strength was rather poor but later in the log the SNR improved. I logged for 82 minutes and got 14,46% decoded audio. The audio bandwidth was only about 3000 Hz and when there was no music, a loud background hum could be heard, probably a ground loop problem. The language spoken was Korean.
Old 29-08-2019, 00:45   #21
28th Aug. 2019
I could not see any traces of DRM on the 28th.
Old 29-08-2019, 19:37   #22
MARCEL
No signal of SDR China and Korea this morning 29.8.19.
DRM:
Mixer Platine MF9 Mhz with Dream
Antenna:
Mantova Turbo 5/8 wave for 27 mhz
Long Wire 80 meter
MARCEL is offline   Reply With Quote
Old 08-10-2019, 21:15   #23
Noted signal on 3560 kHz here in New Zealand last night, October 8, s/off around 16:00 UTC. Presumed North Korea. 0% decoding.
Old 09-10-2019, 01:14   #24
8th Oct. 2019
A DRM test transmission probably from DPRK (North Korea) mostly in Japanese language on 8th October 2019 on 3560 kHz, logged from 0818-1423 UTC. 18,40 kbps EEP, 16-QAM / SM 64-QAM, AAC, Mono.
Protection Level: 1 / 0, Mode B / 9 kHz. Audio: 1 / Data: 0. Interleaver: 400 ms (short).
Intermittent decoded audio (in Japanese) around 0950 UTC. Distorted and overdriven audio. Severe hum, probably caused by a ground loop in the audio line. Unknown DRM power. Distance to the transmitter: about 1150 km (in case it was DPRK).
Logged for 364 minutes. Max. 21,01 dB SNR and 18,19% decoded audio.
Old 10-10-2019, 00:23   #25
9th Oct. 2019
DPRK "Dream Test" logged for 116 minutes from 0834-1030 UTC. Max. 17,82 dB SNR and 13,91% decoded audio. The transmitter shut down at 1026 UTC. Japanese language around 1010 UTC.
