Closed Thread
Old 11-05-2011, 06:12   #1
alokesh
15775 kHz TDP DRM test from Issoudun to India on May 12
TDP Radio will do a DRM test broadcast towards India as follows:
Date : 12 May 2011
Time : 1500-1700 UTC
Frequency : 15775 kHz
Power : 100 kW DRM
Txer Location : Issoudun, France
Alokesh Gupta, VU3BSE
New Delhi, India.
alokesh is offline
Old 12-05-2011, 15:46   #2
I've never heard TDP at such a low audio quality before.
Could not decode much at the beginning, signal got weaker early here.
FritzWue is offline
Old 12-05-2011, 17:24   #3
A weak signal most of the time improving towards the end, perfect decoding for the last five minutes.
simone is offline
Old 12-05-2011, 17:34   #4
lmaes
lmaes's Avatar
Was the bitrate 20.96 kbps as seen in your attachment, or was it 14.56 kbps as was reported by Fritz?
It was not our intention to use a low bitrate and mono, our apologies for that, it will not happen again.
Ludo
lmaes is offline
Old 12-05-2011, 18:00   #5
Dear Ludo,
when I looked at it at the start it was 20.96 kbps as recorded in my logfile, must have changed later but I did not watch it then, will try and check that.
edit: Seems there was a mode change around 1509 UTC, using the TDF configuration then (as usual on 3965 kHz), not sure when the label changed from The Disco Palace to TDPRadio.
Btw funny about the label, as usually it is TDPradio not TDPRadio, so definitely not the normal TDP configuration today.
simone is offline
Old 13-05-2011, 01:15   #6
ramvsankar
Very good reception here in Singapore
Here is a good reception during my monitoring from 1540 to 1600UTC (sorry it was late). Attached screenshot. Very strong signal here in Singapore. Used just 3ft wire antenna (living room) + Elektor SDR 2005 + DREAM 1.13. Actually the signal was overloaded if i use 0 or -10dB. I've to use -20dB in my SDR for 100% decoding.
But, the audio quality was not that good as other DRM stations. 14.56kbps AAC Mono.
When will be the next test tx?
ramvsankar is offline
Old 13-05-2011, 06:03   #7
alokesh
@Simone Label changed from TDPRadio to The Disco Palace at 1600 UTC.
Reception Analysis of 118 mins of log at New Delhi :
SNR Maxm : 20.7
SNR Avg : 18.4
CDA : 88.98%
CDT : 96.38%
New Delhi, India.
alokesh is offline
Old 13-05-2011, 07:35   #8
Hi Alokesh,
thatīs not what I meant, we were discussing the changes in the first 10 minutes or so.
simone is offline
Old 13-05-2011, 12:52   #9
F6AJW
Hello Simone and All at DRMRX,
FYI, new TDP transmission today 13 May from Issoudun towards India: 1500 to 1700 UTC on 15775kHz using TDPRadio and TDP Disco configurations.
Regards.
Jacques
F6AJW is offline
Old 13-05-2011, 16:58   #10
Log 28min . very good but after 1630UTC fading down and strong RTTY in DRM cannel give big problem.
edit: post moved to correct thread, Simone
Sixten is offline
Old 13-05-2011, 17:15   #11
Only a weak signal here, not worth uploading the results but configurations seemed OK today.
Greetings to Jacques for letting us know about the new tests!
simone is offline
Closed Thread
