Old 14-07-2017, 18:47   #16
18H30 this afternoon 14.7.17 very good DRM signal from 15540 Khz and very good audio in arabic :
http://nsa37.casimages.com/img/2017/...1043847066.jpg
Old 14-07-2017, 18:58   #17
DRM Hdn
DRM Hdn's Avatar
Good audio hearable this evening with Sodira and the Technisat Multyradio.
Old 14-07-2017, 19:14   #18
July_14
Finally audio! at ~12kHz BW. One hour log.
When the signal started of dropping decoding errors occurred and I stopped the log. Max SNR noticed 35.8dB.
Old 14-07-2017, 19:39   #19
Hello! Can you post some video or audio to check the audio quality? By the description seems to be Vatican Radio. Thank you!
Old 14-07-2017, 20:23   #20
This is little audio extract from 18H28 UTC, I not can identify, to you is possible !!!!
Voir le Fichier : DRM_UNID_14717_15540_18H28.mp3
Old 14-07-2017, 20:30   #21
Wow! It is the Kuwait radio itself that broadcasts in AM on the same frequency! Great audio quality, similar to RNZI. I hope you get it here in Brazil. Grateful!
Old 14-07-2017, 20:53   #22
Hello Mister Braccini,
No problem, I thank you for confirm that is R.KUWAIT merci beaucoup.
To moment 20H49 UTC signal is always good Oh just 20H50 UTC identification "This is Radio KUWAIT "
73 from Northeast France.
Old 14-07-2017, 21:00   #23
I observed in the sdr of Holland the signal bursting. Here in Brazil I could not capture. Should not be 500 kW, will it?
Old 14-07-2017, 21:05   #24
It was very good tonight, 3 solid hours and it sounded very good throughout. The SNR varied between 21.0 and 25.7db. They gave an address for reports at 1924 UTC, though this wasn't specifically for the DRM, and it seemed to be the same programme that was going out on 963 kHz and other frequencies as well. Now QRT for the night as 2100 UTC is midnight Kuwait time.
Lancashire, UK
53:39.18N 02:10.28W
IO83vp
http://www.ndblist.info
Old 14-07-2017, 21:09   #25
Broadcast in "normal" DRM tonight with 17 kbps AAC+ and P-Stereo in English. Quite good audio quality and "real" stereo and even some quite good English pop music in between the topics. The propagation conditions went sour after 2030 UTC and no more audio.
@John: Most probably they transmit xHE-AAC DRM last night, that was the reason DReaM would not decode anything.
Max. 28.67 dB SNR and about 73% decoded audio.
Old 14-07-2017, 21:10   #26
Hello Mister ALAN,
Is possible to gave my then contact address, I hear then announcement is no very good for my English Hi..........you can send to my address : 14ZK192@gmail.com I thank you.
Yes close signal 21H00 UTC.
Old 15-07-2017, 07:02   #27
14 Jul 2017 : Radio Kuwait on 15540 kHz from Al Kabd
There was 99% decoded audio during the transmission, with good sounding audio up to 12 kHz.
15:00-18:00 UTC Planetary K-index 0+. Local K-index 1.
18:00-21:00 UTC Planetary K-index 0+. Local K-index 1.
Planetary A-index: 4. Solar flux: 89. SESC Sunspot number: 55.
Sunset 20:15 UTC.
Old 15-07-2017, 18:08   #28
Impressive signal here.30 dB SNR
Frequency seems too low by 300 Hz
No audio decoding with dream 1.13
OK with sodira 0.092 quite good quality
Total loss of decoding around 1900 UTC perfect before.
It came back about 20 min later
Old 15-07-2017, 18:26   #29
At 1820-1830 UTC Saturday 15/7/17, I am receiving the Kuwait "DRM Service A" on 15540 here in Newfoundland.
I have both the MR27024 (with eight-metre outdoor wire) and the Avion DR-1401 (with Sony AN-LP1 active antenna attached) and neither one is getting as much as 10% decoding. They are both silent as I type and have been for two or three minutes. When the signal peaks, I hear (very good fidelity) sound for as much as ten seconds before it slips down again.
The Avion is showing MER levels ranging from 3dB to about 12 dB (audio decoding starts above that). The loop picks up the best signal when facing just east of North.
Philip
Old 15-07-2017, 19:34   #30
DRM Hdn
DRM Hdn's Avatar
15 Jul 2017 : Radio Kuwait on 15540 kHz from Sulaibiyah
Here today very good signal with ~25 dB SNR.
No audio decoding with my dream version but sodira works fine.
