Old 18-11-2017, 13:38   #46
Nov_18
A mostly unattended log for 61 mins, 99.99% CDA / 33.6dB max SNR.
Old 18-11-2017, 20:49   #47
This is an older log from the 11th November which I received via a KiwiSDR in Zittau. I modified the "My Locations" in the DRM Plotter to calculate the Latitude and Longitude for the Maidenhead Grid as published for the SDR. Thanks to Zyg for the idea which I implemented just a few hours ago.
Old 19-11-2017, 10:46   #48
18 Nov 2017 : Radio Kuwait on 15110 kHz from Al Kabd
There was 99+% decoded audio during the transmission.
06:00-09:00 UTC Planetary K-index 2. Local K-index 1.
09:00-12:00 UTC Planetary K-index 2-. Local K-index 1.
12:00-15:00 UTC Planetary K-index 1+. Local K-index 2
Planetary A-index: 6. Solar flux: 75. EISN Sunspot number: 15.
Sunrise 07:26 UTC.
Old 19-11-2017, 13:37   #49
Nov_19
A 135 mins log, 99.92% CDA / 34.4dB max SNR.
Old 19-11-2017, 22:36   #50
19 Nov 2017 : Radio Kuwait on 15110 kHz from Al Kabd
06:00-09:00 UTC Planetary K-index 2. Local K-index 2.
09:00-12:00 UTC Planetary K-index 1+. Local K-index 1.
12:00-15:00 UTC Planetary K-index 0+. Local K-index 1
Planetary A-index: 6. Solar flux: 75. EISN Sunspot number: 0.
Sunrise 07:28 UTC.
Old 21-11-2017, 13:47   #51
15110 kHz Radio Kuwait Reception near Atlanta, Georgia, USA
This morning's reception - 0.22% audio decoded, 10.57 dB max SNR.
Old 22-11-2017, 14:17   #52
Nov_22
An unattended log for 100 mins, 98.8% CDA / 34.4dB max SNR.
Old 24-11-2017, 13:54   #53
Nov_24
A partially unattended log for 109 mins, 99.2% CDA / 33.9dB max SNR.
Old 25-11-2017, 10:54   #54
Nov 25 via Leiden Netherlands SDR
1030-1045 with Middle East current affairs program in Arabic.
Pleasant listening with the signal dropping out but never for long.
The SNR was bouncing around 10 dB never much above or below.
73s,
Hans
Old 25-11-2017, 12:59   #55
Here in downtown St. John's, Newfoundland, the local noise level is too high to get any decoding on this morning's 15110kHz DRM from Kuwait. But I am receiving its label, with MER levels of sometimes zero, but up to eight or ten at best. Nothing high enough to go over the decoding threshhold. Right now it is 1250UTC and I've been checking since 1230.
[Both MR27024 with eight-metre wire, and Avion with Sony AN-LP1 loop.]
Old 25-11-2017, 13:40   #56
Nov_25
A mostly unattended log for 212 mins, unstable signal although I got 99.75% CDA / 34dB max SNR.
Old 25-11-2017, 16:23   #57
This morning's reception - no audio decoded, 8.06 dB max SNR.
Old 28-11-2017, 14:39   #58
This morning's reception - 0.02% audio decoded, 11.74 dB max SNR.
Old 29-11-2017, 13:59   #59
Nov_29
A 224 mins log (the transmission lasted until 13:40).
Mediocre signal + fading. The signal turned better after ~12:20.
99.23% CDA / 33.6dB max SNR.
Old 29-11-2017, 17:52   #60
This morning's reception - 0.69% audio decoded, 13.38 dB max SNR.
The transmission continued past the end of the logging time.
In also monitored the reception via a KiwiSDR web receiver located on the coast of Massachussets where the signal was much stronger and consequently good audio decoding.
